POV-Ray : Newsgroups : povray.unofficial.patches : media problems Server Time
17 May 2026 18:26:41 EDT (-0400)
  media problems (Message 1 to 10 of 12)
Subject: media problems
Date: 17 May 2000 11:56:28
Message: <3922c12c@news.povray.org>
Could someone explain to me, why scattering 2 & 4 media render very
differently in megapov 05 from the way they do in 04. What changes have been
made and is there anything I can do to modify media in 05 so that it renders
the same as in 04.
Mick
Subject: Re: media problems
Date: 17 May 2000 19:30:21
Message: <39232b8d@news.povray.org>
Mick,
It's not the media.  It's the "noise3d" fix.  Use
#version unofficial MegaPov 0.4;
to revert to the old (buggy) noise3d if you need to.
-Nathan
Mick Hazelgrove <mha### [at] redhotantcom> wrote...
been
renders
> the same as in 04.
> Mick
Date: 17 May 2000 20:38:41
Message: <39232DBB.4C55665D@peak.edu.ee>
I suspect there is something funny about media. I am working on a cloudscape and
switching to 0.5 immediately led to all sorts of weirdness. I'm still
researching the matter, but here is one observation: method 3 media tends to
render as black if minimum samples is set to 1. Raising it usually helps, but
I've had to go as high as 20 to eliminate some weird banding. Method 2 media
sometimes acts up too, but overall the behaviour seems kind of chaotic (i.e. I
haven't made the connection yet).
Could it perhaps be connected to the constant media speed enhancement? How does
this work?
Margus Ramst
Date: 18 May 2000 00:00:53
Message: <39236af5$1@news.povray.org>
Margus Ramst <mar### [at] peakeduee> wrote...
cloudscape and
to
but
media
(i.e. I
does
> this work?
It's possible.  The speedup works like this:
If the ray in question is a shadow ray (meaning that we are only determining
how much light is blocked as the light travels through the media) and all
participating media are constant, then POV will use one interval, and one
sample using media method 1 instead of the user-selected method.  The reason
is that no other samples are needed.  A single sample will give us the
density, and we really don't care how much light is hitting the media along
the path of the ray, because we only care how much light was blocked as the
beam of light traveled along the ray.  Does that make sense?
-Nathan
Date: 18 May 2000 02:46:06
Message: <392391ae$1@news.povray.org>
I've hit two problems
    i) brightness, easily solved
    2) the interaction of two medias is completely different. the media
seems to almost dissapear.This is the one where I can't find the logic. or
get any control, Now that Nathan has explained I can see why, but not how to
compensate.
Mick
"Nathan Kopp" <Nat### [at] Koppcom> wrote in message
news:39236af5$1@news.povray.org...
> cloudscape and
tends
> to
helps,
> but
> media
> (i.e. I
How
> does
> > this work?
determining
reason
along
the
> -Nathan
Date: 18 May 2000 12:19:26
Message: <39240A3D.B4A6DD96@peak.edu.ee>
No, I don't think this is the culprit. The same happens with both constant and
non-constant densities, emitting, absorbing and scattering media. The media is
opaque to both camera and shadow rays. I'm beginning to think that the adaptive
mechanism is broken somehow.
Margus Ramst
Date: 18 May 2000 12:46:50
Message: <39241e7a$1@news.povray.org>
and
media is
adaptive
Does it really happen with emitting media?  There was a change made to
extinction/absorption of media method 3, but that shouldn't affect emitting
media.  (There may be some other issues that affect media method 3, though).
-Nathan
Date: 18 May 2000 13:20:44
Message: <3924189A.3A58D216@peak.edu.ee>
It does, with the exception that the media won't cast a shadow (as expected).
I am not the only one affected, am I?
Here's a little scene that should demonstrate the problem:
#version unofficial megapov 0.5;
camera{location <2,3,-5> look_at 0}
light_source{<-50,50,-50> color 1 }
sphere{0,1
    pigment{rgbf 1}
    finish{ambient 0 diffuse 0}
    interior{media{method 3 samples 1 emission 1}}
    hollow
    translate y
plane{y,0 pigment{checker .3,.6} finish{diffuse .7 ambient 0}}
Margus Ramst
Date: 18 May 2000 13:28:30
Message: <3924283e@news.povray.org>
expected).
Actually, emitting media is not supposed to cast a shadow.  Only absorbing
and scattering media will cast shadows.
-Nathan
Date: 18 May 2000 13:30:08
Message: <392428a0@news.povray.org>
expected).
There was a bug if you choose 3 or fewer samples, and I've found it and
fixed it.  There may be other bugs, though.
-Nathan
