POV-Ray : Newsgroups : povray.unofficial.patches : Bug in csqr? Server Time
17 May 2026 18:24:09 EDT (-0400)
  Bug in csqr? (Message 1 to 4 of 4)
Subject: Bug in csqr?
Date: 17 May 2000 09:20:34
Message: <39229ca2@news.povray.org>
Try the following. Both printed lines should be identical (or at least
almost identical). However, only the first one is the correct answer. The
second one is buggy:
$Z = <-.32, -1.97>;
$Z2 = cmult(Z,Z);
#debug concat("cmult(<",str(creal(Z),10,10),",",str(cimag(Z),10,10),">) = ")
#debug concat("<",str(creal(Z2),10,10),",",str(cimag(Z2),10,10),">\n")
$Z2 = csqr(Z);
#debug concat(" csqr(<",str(creal(Z),10,10),",",str(cimag(Z),10,10),">) = ")
  In this Solaris 7 it outputs the following:
cmult(<-0.3200000000,-1.9700000000>) = <-3.7785000000,1.2608000000>
 csqr(<-0.3200000000,-1.9700000000>) = <-3.7785000000,14.8872900000>
Subject: Re: Bug in csqr?
Date: 17 May 2000 09:25:08
Message: <39229db4@news.povray.org>
Btw, I seriously think someone should check _all_ the complex functions
to see if they have bugs. Tried 3 functions (cpow, csqr, cmult) and 2 of
them didn't work correctly. That's a too high percentage.
Date: 17 May 2000 10:30:56
Message: <3922ad20$1@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote in message news:39229ca2@news.povray.org...
> $Z = <-.32, -1.97>;
> $Z2 = cmult(Z,Z);
> $Z2 = csqr(Z);
Yes, csqr(Z) has a bug.
The source-level fix is to replace a line in express.c.
===== the bug ===========================
         case CSQR_TOKEN:
            #ifdef UnofficialBlocking
              parseUnofficialFeature(40);
            #endif
            Parse_Vector_Param(Vect);
/**** Replace the next line:*****/
Make_Vector(Vect,Vect[0]*Vect[0]-Vect[1]*Vect[1],2*Vect[0]*Vect[1],0.0);
            break;
===== a fix ========================
         case CSQR_TOKEN:
            #endif
/***** Replacement lines*********/
            cmplx2.x=Vect[0];cmplx2.y=Vect[1];
Make_Vector(Vect,cmplx2.x*cmplx2.x-cmplx2.y*cmplx2.y,2*cmplx2.x*cmplx2.y,0.0
            break;
Date: 17 May 2000 10:43:56
Message: <3922b02c@news.povray.org>
david sharp <dsh### [at] interportnet> wrote:
: Yes, csqr(Z) has a bug.
  Ok. It's good to know that it's not just me... :)
