POV-Ray : Newsgroups : povray.unofficial.patches : 2 Problems with Megapov .5 Server Time
27 Jul 2026 20:36:50 EDT (-0400)
  2 Problems with Megapov .5 (Message 21 to 25 of 25)
Subject: Re: 2 Problems with Megapov .5
Date: 18 May 2000 11:34:36
Message: <39240CBE.DD6803E5@pacbell.net>
Glen Berry wrote:
> Unless I'm mistaken, not everyone can run the MSVC compile. Doesn't
> that require a recent model of Pentium processor to work properly?
The MSVC pentium II compile can be run on any windows machine as
far as I know. I have a PI 200 mmx and it runs with no problem.
In fact even though it is optimized for a PII I still realize a
little faster performance over the watcom compile of the program.
The standard Windows distribution is compiled with watcom PII
optimized so there is little difference.
Date: 18 May 2000 12:14:50
Message: <39241DD6.58769B21@merlin.net.au>
Ken wrote:
> PoD wrote:
> > I agree, how many people use the MS-DOS version?
> Still quite a few using it from what I have heard. Chris Colefax
> for example still uses the dos version for all of his include file
> development work.
OK, I didn't think that many people would be using it and I didn't mean
any offence.
However there's no reason to limit all other platforms to 8.3 filenames
anyway.
The proposal to use an #ifdef seems the best solution.
PoD.
Date: 20 May 2000 06:02:34
Message: <392662ba@news.povray.org>
PoD <pod### [at] merlinnetau> wrote in message
news:3922F223.BA027B9D@merlin.net.au...
> Warp wrote:
> >   I would suggest some #ifdef's in the povray source code. If we
are NOT
> > compiling for DOS, then just use as long file names as needed. If
we are
> > compiling for DOS, then truncate and don't care about the
consecuences.
I do for one, and my other box doesn't even have windoze installed.
I would accept Warp's suggestion though.
Alf
http://www.peake42.freeserve.co.uk/
http://ourworld.compuserve.com/homepages/Alf_Peake/
Date: 23 May 2000 01:54:02
Message: <QhwqOdnmRebAvKiE9yONBkUb3ZoI@4ax.com>
Yes, but which #ifdef proposal? I hope you are refering to the one
that uses #ifdef to modify the DOS version to create subdirectories,
and place sequentially numbered files into it.
There was another proposal that involved #ifdef and filename
truncation/mangling, without subdirectory creation. I don't like that
idea nearly as well.
Later,
Glen Berry
( Remove the "7" from 7no### [at] ezwvcom to email me. )
Date: 23 May 2000 05:49:30
Message: <392a542a@news.povray.org>
Glen Berry <7no### [at] ezwvcom> wrote:
: Yes, but which #ifdef proposal? I hope you are refering to the one
: that uses #ifdef to modify the DOS version to create subdirectories,
: and place sequentially numbered files into it.
: There was another proposal that involved #ifdef and filename
: truncation/mangling, without subdirectory creation. I don't like that
: idea nearly as well.
  I really don't care which one as long as I get long filenames here :)
