POV-Ray : Newsgroups : povray.unofficial.patches : Radiosity feature suggestion Server Time
23 Mar 2026 05:51:49 EDT (-0400)
  Radiosity feature suggestion (Message 1 to 10 of 11)
Subject: Radiosity feature suggestion
Date: 14 May 2000 13:15:17
Message: <391edf25@news.povray.org>
I came up with this idea while talking to Mark Wagner on ICQ yesterday. I
was trying to figure out the radiosity settings that Nathan provides, and
discovered I was clueless about brightest_ambient_object. I was using
totally incorrect numbers, and Mark cleared this up for me. What I am
proposing is the following: How about adding some way of making this value
be automatically calculated for adc_bailout? You know, like adding the
keyword "auto" after adc_bailout, or something like that. Could it be done?
Would it help?
Subject: Re: Radiosity feature suggestion
Date: 15 May 2000 06:54:18
Message: <391fd75a@news.povray.org>
I think this is a good idea (if it can be done).
  The more values that are automatically calculated (but of course modifiable
by hand when needed), the better.
  If the automatically calculated value is bad for a certain scene, you can
fine-tune it by hand, but if the program can automatically calculate a good
value which works for most scenes, that would make it a lot easier to use.
Date: 15 May 2000 09:08:26
Message: <391FF698.81E8B2C@iastate.edu>
Can you share what you learned with us?
Mike Wilson
Date: 15 May 2000 19:23:21
Message: <392086e9@news.povray.org>
brightest_ambient_object = average of the RGB of the brightest color times
its diffuse. Quoting from Mark Wagner's message to me, this means:
"An object with a color of < 1, 0.5, 0.5 > and a diffuse of 0.8 would have
an average color of 2/3 and a total brightness of 8/15 or 0.53.  An object
with a color of < 2, 2, 2 > and a diffuse of 0.25 would have an average
color of 2 and a total brightness of 0.5.  If your scene consisted of only
those two objects, you would use 0.53 for the brightest_ambient_object."
Date: 15 May 2000 20:26:08
Message: <392095a0$1@news.povray.org>
Of course, if the light source you use had a brightness of 1.5 instead of
1.0, then you'd want to use 0.53 * 1.5 for that value.
-Nathan
TonyB <ben### [at] panamac-comnet> wrote...
Date: 16 May 2000 04:59:56
Message: <39210e0c@news.povray.org>
All this is good to know.  I too was wondering about it.
"Nathan Kopp" <Nat### [at] Koppcom> wrote in message news:392095a0$1@news.povray.org...
{ Of course, if the light source you use had a brightness of 1.5 instead of
{ 1.0, then you'd want to use 0.53 * 1.5 for that value.
{ -Nathan
{ TonyB <ben### [at] panamac-comnet> wrote...
{ > brightest_ambient_object = average of the RGB of the brightest color times
{ > its diffuse. Quoting from Mark Wagner's message to me, this means:
{ > "An object with a color of < 1, 0.5, 0.5 > and a diffuse of 0.8 would have
{ > an average color of 2/3 and a total brightness of 8/15 or 0.53.  An object
{ > with a color of < 2, 2, 2 > and a diffuse of 0.25 would have an average
{ > color of 2 and a total brightness of 0.5.  If your scene consisted of only
{ > those two objects, you would use 0.53 for the brightest_ambient_object."
Date: 16 May 2000 09:12:08
Message: <39214920.4B8A8F60@iastate.edu>
If you have multiple light_sources do you just use the value of the brightest
one in your calculations, or do you need to figure each one's contribution and
find an average or something?
Mike Wilson
> -Nathan
Date: 16 May 2000 09:39:49
Message: <39214fa4@news.povray.org>
Mike Wilson <maw### [at] iastateedu> wrote:
: If you have multiple light_sources do you just use the value of the brightest
: one in your calculations, or do you need to figure each one's contribution and
: find an average or something?
  And of course it will not be the same thing if the light sources are both
illuminating the same side of the object or opposite sides...
Date: 16 May 2000 17:44:44
Message: <3921c14c@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:39214fa4@news.povray.org...
{ Mike Wilson <maw### [at] iastateedu> wrote:
{ : If you have multiple light_sources do you just use the value of the brightest
{ : one in your calculations, or do you need to figure each one's contribution and
{ : find an average or something?
{   And of course it will not be the same thing if the light sources are both
{ illuminating the same side of the object or opposite sides...
Sounds a bit more complicated now.
Date: 16 May 2000 21:07:55
Message: <3921f0eb@news.povray.org>
To make it easier, simply estimate on the bright side (for adc_bailout).
That might decrease speed, but will help image quality.
-Nathan
Bob Hughes <per### [at] aolcom?subject=PoV-News:> wrote...
brightest
contribution and
both
> Bob
