POV-Ray : Newsgroups : povray.unofficial.patches : Post process feature: copy Server Time
17 Jul 2025 16:05:36 EDT (-0400)
  Post process feature: copy (Message 1 to 7 of 7)
Subject: Post process feature: copy
Date: 14 May 2000 04:57:41
Message: <391E6A2A.C09319D2@stud.ntnu.no>
Needless to say render and parse time can be very long, thus making it slow
to experiment with the post processes. With a copy{} object one could output
several different versions of the file:
post_process {
   copy { png "no_postprocess.png" }
   copy { png "focal_and_soft.png"
      focal_blur{10,5,2}
      soft_glow{.6,5}
sig
Subject: Re: Post process feature: copy
Date: 14 May 2000 09:30:25
Message: <chrishuff_99-B00382.08335214052000@news.povray.org>
In article <391E6A2A.C09319D2@stud.ntnu.no>, Sigmund Kyrre Aas
> it slow to experiment with the post processes. With a copy{} object
> one could output several different versions of the file:
> post_process {
>       focal_blur{10,5,2}
>       soft_glow{.6,5}
I think a better solution would be input_image and output_image
directives for each process. The input_image keyword would load the
specified image and use it to override the color values, output_image
would save the results of the filter to the specified file and restore
the previous version in memory. It would probably have to be clipped
colors to be a standard image format, but that shouldn't be a big
problem(you could find or create another image format supporting a
greater dynamic range).
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 14 May 2000 11:24:06
Message: <391ec516@news.povray.org>
Like RGBE! :)
Date: 14 May 2000 12:50:51
Message: <chrishuff_99-B0646C.11541814052000@news.povray.org>
In article <391ec516@news.povray.org>, "TonyB"
<ben### [at] panamac-comnet> wrote:
> Like RGBE! :)
Perhaps...I have downloaded the source and will be playing around with
it, maybe I will make a C++ version. I will need to make a converter to
some other format though...
Anyone know of some good source code for reading/writing TGA, PPM, etc?
I have looked for some, but the closest thing I could find is the file
specifications, and since I am extremely inexperienced with file
handling, I would prefer to work from existing code. I suppose I could
just look at the POV code, but I would rather have some code already
separate and useable.
Date: 14 May 2000 17:57:31
Message: <391F2151.9BF60326@stud.ntnu.no>
Ahh, uuh. 'Fraid I didn't understand this, but if you say it'll do the
trick.. (What is the "previous version"? What do you mean by overriding
colour values?)
sig
Date: 14 May 2000 18:45:07
Message: <chrishuff_99-3CFAD7.17483414052000@news.povray.org>
In article <391F2151.9BF60326@stud.ntnu.no>, Sigmund Kyrre Aas
> colour values?)
The "previous version" is what the in-RAM image looks like before the
filter is called. If an input file is specified, colors from the file
are used instead of that version(they override the original colors). If
an output file is specified, the results of the filter are saved to the
file and the in-RAM image is not affected.
Date: 14 May 2000 23:50:53
Message: <391f741d@news.povray.org>
Sigmund Kyrre Aas <as### [at] studntnuno> wrote...
slow
output
In MegaPov 0.5, the non-processed file will be kept by default, and a new
file (with "_PP" appended to the end) will be created for the post-processed
version.  You will be able to revert to the old behavior with the keyword
"overwrite_file".
Better file control (such as what you suggest or something like what Chris
proposed) is planned for the future, but not for this release.
-Nathan
