POV-Ray : Newsgroups : povray.unofficial.patches : Photon bug Server Time
7 Oct 2024 04:22:25 EDT (-0400)
  Photon bug (Message 1 to 4 of 4)
Subject: Photon bug
Date: 13 May 2000 16:41:10
Message: <391DBDEA.66FBEB6F@stud.ntnu.no>
There appears to be a bug with photons and texture_map. Consider a typical
photon scene: a refractive object with a floor beneath - Then the
transformation of the floor affects the way caustics appear if the floor has
a texture map.
This animation will demonstrate the effect:
#version unofficial MegaPov 0.4;
$Lpos=<3,5,-5>*6;
light_source { 0, 2  translate Lpos }
// Try these one at a time:
$Pigment_map=0;     // this is ok
$Plain_colour=0;    // ditto
$Texture_map=1;     // this is not ok
$T=.55;//clock;  // clock from 0 through 1
// T=0.5 correspond to no transformation and will produce
// correct results with all the above pigments
   location  <0, 10 ,-10>
   look_at 0
   rotate 90*y
global_settings{
    max_trace_level 12
    photons{
        count 20000
        autostop 0
$Ruby_mat=material {
        pigment {rgb x filter 0.95}
        finish {specular .4 roughness .01}
    interior { ior 1.06}
$C1=<120,1,165>/255;
$Plane=plane{y,.3
#if(Plain_colour) pigment {rgb C1} #end
#if(Texture_map)
        marble
        texture_map {
            [.5 pigment {color C1} ]
            [.5 pigment {color C1*1.4} ]
#if(Pigment_map)
        marble
        pigment_map {
            [.5 color C1 ]
            [.5 color C1*1.4 ]
object {Plane translate <-5+T*10, 0, -5+T*10>}
$k=0;$l=0;$counter=0;
#while (k<=1)
    #while (l<=1)
        box {-.5,.5
            material {Ruby_mat}
            photons { target refraction on}
            $Pos=<-5+k*10, 0, -5+10*l>;
            translate Pos+(Lpos-Pos)*.04 +y*.3
        $counter=counter+1;
        $l=l+1/3;
    $l=0;
    $k=k+1/3;
Subject: Re: Photon bug
Date: 13 May 2000 19:12:57
Message: <391de179@news.povray.org>
Yes, I see there is a problem.
I'm working on finding a solution.
-Nathan
Sigmund Kyrre Aas <as### [at] studntnuno> wrote in message
news:391DBDEA.66FBEB6F@stud.ntnu.no...
has
> a texture map.
Date: 14 May 2000 00:57:23
Message: <391e3233@news.povray.org>
OK.  I found the bug and fixed it.
-Nathan
Sigmund Kyrre Aas <as### [at] studntnuno> wrote...
has
> a texture map.
Date: 14 May 2000 04:57:42
Message: <391E6A43.23D7B27E@stud.ntnu.no>
Great! Will version 0.5 be out anytime soon?
sig
