I just spent two hours figuring out why I didn't get any photons when I
found that a looks_like{sphere .. statement in my light_source was to blame.
Adding pass_through for the sphere corrected this, but wouldn't it be a good
idea to have it set as default for looks_like objects?
sig
In general photons act a bit ilogically with shadowless object. When you
make an object shadowless and the light passes through that object, it's
logical to expect photons to pass through as well. I don't know why the
shadowless-keyword is ignored by the photons calculations.
Warp <war### [at] tag povray org> wrote...
Photon interaction with objects is a bit more complicated than shadow-ray
interaction. However, it's not to difficutl to make no_shadow work like
pass_through. This will decrease the amount of control you have over your
objects (currently, you can have an object that uses no_shadow but not
pass_through, but if I make this change then you will not be able to use the
no_shadow feature without the pass_through feature). Comments?
-Nathan
Yes, well I don't know either why there's a seperate keyword for photons and
regular lights. More flexibility I guess. What I'm saying is that
pass_through could have been enabeled by default for looks_like objects,
just as shadowless is.
sig
> pass_through,
I think this is good because, even if this is perhaps not logical,
this allow more control and effect in a scene.
Fabian.
Nathan Kopp <Nat### [at] kopp com> wrote:
: Photon interaction with objects is a bit more complicated than shadow-ray
: interaction. However, it's not to difficutl to make no_shadow work like
: pass_through. This will decrease the amount of control you have over your
: objects (currently, you can have an object that uses no_shadow but not
: pass_through, but if I make this change then you will not be able to use the
: no_shadow feature without the pass_through feature). Comments?
I think that a compromise could be the perfect solution:
By default, applying no_shadow to an object also applies pass_through
to it.
If you don't want photons passing through, you can specify it like this:
object
{ MyObject
no_shadow
photons { pass_through off }
I agree.
> sig
Sorry, replace shadowless with no_shadow.
