POV-Ray : Newsgroups : povray.unofficial.patches : colors and glowing Server Time
16 Jun 2026 07:44:22 EDT (-0400)
  colors and glowing (Message 1 to 10 of 17)
Subject: colors and glowing
Date: 8 May 2000 11:48:05
Message: <3916E1B5.DC497C5A@student.kuleuven.ac.be>
How about adding a 5th color channel: glow.
Every pixel that has a glow-value of 1 will glow with a pixel-radius
given in the global_settings.  0.5 will glow with half the intensity.
I hope you understand what I mean...?
ZK
http://www.povplace.be.tf
(You'll get an error-message if you follow that link.  Don't worry,
it's not important, it's just a JAVA-error...)
Subject: Re: colors and glowing
Date: 8 May 2000 17:52:36
Message: <chrishuff_99-09163D.16555508052000@news.povray.org>
In article <3916E1B5.DC497C5A@student.kuleuven.ac.be>, Zeger Knaepen
Umm, colors already have 5 channels(r, g, b, f, and t). And this sounds
like something which will be taken care of by post_process filters...no
need to modify something as basic as the color.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 8 May 2000 18:02:15
Message: <39173967$1@news.povray.org>
In article <chrishuff_99-09163D.16555508052000@news.povray.org> , Chris Huff
<chr### [at] yahoocom>  wrote:
> And this sounds
Hmm, and what about objects in a mirror?
       Thorsten
Date: 8 May 2000 18:53:56
Message: <chrishuff_99-2DAF25.17571308052000@news.povray.org>
In article <39173967$1@news.povray.org>, "Thorsten Froehlich"
It depends on the filter...the most realistic way to do this seems to be
to make a glow effect around extremely bright areas. This would work
fine in a mirror. Otherwise, you should probably use emitting media,
which also works in a mirror. If you use a per-object glow filter,
reflections won't work, and neither will refracted portions.
How could this be done without a post_process filter, and without media?
They seem to be the only solutions, and they work pretty well...maybe
some more stuff from POV-AFX could be added, though.
Do you really think adding a "glow" component to colors is the best way
to do it?
Date: 8 May 2000 21:22:24
Message: <39176851.C44A0F73@student.kuleuven.ac.be>
The 6th color-element (glow) would have nothing to do with the actual
render-process.  The post-processor would use it to check if it should
add the glow or not.  I think this way is the most flexibel way to
implement the glowing.  Per-object glowing wouldn't be interesting, I
think.  Say I have a spaceship with windows.  The windows would be a
texture, but I would still want them to glow.  So for the lit windows
I would use something like:
rgb 1 glow 1
This method gives no problem with mirrors, because the glow_amount (or
whatever you call it) is part of the color which get reflected.
Refraction wouldn't give a problem either.
ZK
> to do it?
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> TAG Web page: http://tag.povray.org/
Date: 8 May 2000 22:51:27
Message: <39177d2f$1@news.povray.org>
In article <chrishuff_99-2DAF25.17571308052000@news.povray.org> , Chris Huff
> to do it?
No, surely not.  Glow seems to be more of an additional kind of object (not
color) property to me.
      Thorsten
Date: 9 May 2000 08:31:34
Message: <39180526$1@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote...
Huff
> > to do it?
(not
However, the concept sounds very interesting to me.  Keeping this at 'glow'
seems a bit limiting, but if this were to be extended to contain some form
of general object information that would be used by the post-processing
filters, that might make it worthwhile.  Of course, adding a 6th component
to the color vector would cause a loss of performance (decreased speed and
increased memory usage).  Anyway, it is a creative idea that is at least
worth considering.
-Nathan
Date: 9 May 2000 20:46:54
Message: <3918b17e@news.povray.org>
I agree.
Date: 9 May 2000 22:59:04
Message: <chrishuff_99-150F90.22022409052000@news.povray.org>
In article <39180526$1@news.povray.org>, "Nathan Kopp"
> 'glow' seems a bit limiting, but if this were to be extended to
> contain some form of general object information that would be used by
> the post-processing filters, that might make it worthwhile.  Of
> course, adding a 6th component to the color vector would cause a loss
> of performance (decreased speed and increased memory usage).  Anyway,
> it is a creative idea that is at least worth considering.
I don't think it belongs in the color vector though. Of course, I don't
think filter and transmit belong there either...I think they should be
separate colors.
Maybe instead of adding things to the color vector, an "effect_map"
object attribute would work...
Date: 9 May 2000 23:03:59
Message: <chrishuff_99-B46AD8.22071909052000@news.povray.org>
In article <39176851.C44A0F73@student.kuleuven.ac.be>, Zeger Knaepen
Then don't use per-object glowing, use brightness-threshold glowing. The
windows are probably brighter than the surrounding hull, otherwise they
wouldn't be glowing, so set the filter to make things at or above the
"window brightness" glow.(I already have a sort-of-working version of
this kind of effect, though it will be a while before I have anything
useful.)
Or maybe additional information could be patterned and passed to the
post_process stage with some kind of "effect_map". Certainly a better
alternative than adding more stuff to color, where it doesn't really
belong(for one thing, you could have a glow map independant of the
pigment map).
