POV-Ray : Newsgroups : povray.unofficial.patches : Question about functions ??? Server Time
19 Mar 2026 07:10:22 EDT (-0400)
  Question about functions ??? (Message 1 to 6 of 6)
Subject: Question about functions ???
Date: 7 May 2000 22:56:46
Message: <39162CF3.8B9D708@kh.rim.or.jp>
Dear Sirs;
I am compilig Mega 0.4 version by Apple MPW MrC Compiler.
So I notice that (1)max_extent,min_extent,(2)trace functions
depend on Memory Allocation System of each OS.
(1),(2) are samples from IRTC stills 2000/04
And (3)#macro's argument includes Reserved Word then crash,
when do I check Test ReDefine argument ?
drunkpat.zip:
BackGround.inc:
#macro Cable(Point1,Point2,CableRadius,SlackAmount,NumNodes,NumPoints):
union
 CablewoBounds
 bounded_by {box{max_extent(CablewoBounds),min_extent(CablewoBounds)}}
 clipped_by {bounded_by}
My Apple stop this Error:
"Unknown box side in Box_Normal()"
(2)trace
jw_cits.zip:
jw_cits.pov:
#declare _landscape = function { "ridgedmf",<1,2,10,1.1,2> }
object { landscape }
#local cam_l = <0,2,0>+trace(landscape,cam_l+y*1000000,y*-1);
My Apple first time show dark and stop, then try again makes fine scene.
Maybe second time can catch actual memory location, I think.
(3)#macro
#macro(r,s)
Y.Tanabe
Kobe,Japan
tec### [at] khrimorjp
Subject: Re: Question about functions ???
Date: 8 May 2000 09:48:54
Message: <slrn8hdiaj.9pe.ron.parker@linux.parkerr.fwi.com>
On Mon, 08 May 2000 11:56:54 +0900, Y.Tanabe wrote:
>Dear Sirs;
Unlikely.  They don't do any memory allocation.  It's possible that
the object you're working with isn't bounded correctly by POV, though.
>(3)#macro
>#macro(r,s)
r and s are reserved words.  Don't use them.  To avoid such collisions
in the future, make sure all #defined names (including macro parameters
and #local variables) contain at least one capital letter.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
These are my opinions.  I do NOT speak for the POV-Team.
Date: 10 May 2000 01:01:41
Message: <3918ED3B.DE6A0FD2@kh.rim.or.jp>
Thanks Mr.Ron
I mean when the object confirm their actual Bounding Box Size.
For example,"ridgedMF" calculate thier height by recursive calculating,I
think.
So "ridgedMF" use inside of #macro define,normaly macro returns value or
object etc.,
that time "ridgedMF" can return correct Bounding Box or not.
The above point that I know.
Y.Tanabe
Kobe,Japan
techflux @kh.rim.or.jp
> >(3)#macro
> >#macro(r,s)
Date: 11 May 2000 14:42:32
Message: <slrn8hm0co.1vs.ron.parker@linux.parkerr.fwi.com>
On Wed, 10 May 2000 14:01:51 +0900, Y.Tanabe wrote:
>Thanks Mr.Ron
>think.
>object etc.,
min_extent and max_extent only return the size of the current bounding
box, which is not necessarily the smallest box that surrounds the object.
So your sample code is meaningless; it won't put any tighter bounds on the
object than already exist.  If your object is an isosurface, min_extent
and max_extent will likely return the bounding box of the contained_by
object or of the bounded_by object if one was specified.
Date: 12 May 2000 04:44:11
Message: <391bc45b@news.povray.org>
What does min_extent and max_extent return for an infinite surface
(plane, poly)?
Date: 12 May 2000 11:05:12
Message: <slrn8ho81q.36e.ron.parker@linux.parkerr.fwi.com>
>(plane, poly)?
Probably the large numbers POV itself uses to represent infinite or
half-infinite bounding boxes.
