POV-Ray : Newsgroups : povray.unofficial.patches : Problem with UV_mapping and Mesh Server Time
7 Oct 2024 06:26:41 EDT (-0400)
  Problem with UV_mapping and Mesh (Message 1 to 10 of 18)
Subject: Problem with UV_mapping and Mesh
Date: 25 Apr 2000 05:16:34
Message: <39056267.46BBC99D@umh.ac.be>
Hello All,
I have some trouble with UV_mapping and Mesh/Mesh2. All is ok with
bicubic patch but with mesh, I cannot get the whole texture on the
object even if I scale down??
The code can be found at pov.bin.scene-file and the image at
pov.bin.images. The code is long but you just need to look the lest
lines of code.
Thanks to help me :).
Fabian.
Subject: Re: Problem with UV_mapping and Mesh
Date: 25 Apr 2000 05:54:36
Message: <39056BB8.19C33CED@aetec.ee>
Fabian BRAU wrote:
> Hello All,
> lines of code.
> Fabian.
Hello!
How did you create this mesh2? I don't know about mesh2 format very
much, but I tried to create mesh2 from Rhino (via export to 3DS format
and 3ds2pov converter) and saw, that it contains uv_vectors section
after normal_vectors, but in your example file such section is missing.
So, I guess that in your mesh2 there is missing uv-information and some
default value (0?) is used for u and v.
HTH
Date: 25 Apr 2000 06:15:41
Message: <39057042.E628CFD9@umh.ac.be>
Hello,
This mesh was create by spatch, export in dxf, convert in udo/inc (mesh)
and after convert into mesh2 with the tools of Warp (nieminen juha).
This problem appear to me for every mesh/mesh2 (even mesh) I use.
In the doc, it say that uv_mapping works for mesh/mesh2.
Fabian.
> Fabian BRAU wrote:
> > Hello All,
> > lines of code.
> > Fabian.
> Hello!
> HTH
Date: 25 Apr 2000 07:30:38
Message: <39058235.84DB5C4E@aetec.ee>
Fabian BRAU wrote:
> Hello,
Yes, uv mapping works for mesh(mesh2), but in order to have correct
output, it needs information about u and v values. AFAIK, none of the
programs, mentioned above, support (output) this information. I'm afraid
that if you want to use uv mapping with given tools, you have to use
bicubic patch. May-be there is alternatives, but I'm not aware of them.
Date: 25 Apr 2000 07:53:28
Message: <3905872F.1B8D5AAE@umh.ac.be>
I don't how you can give u and v values information with mesh
syntax? But one says that uv_maping work with mesh! So...
Fabian.
> Fabian BRAU wrote:
> > Hello,
Date: 25 Apr 2000 08:44:58
Message: <3905939C.FBB6E7A3@aetec.ee>
> Fabian.
Perhaps I should leave this problem to people with better knowledge of
uv-mapping in POV-Ray, as I'm quite ignorant in this area. (When Nathan
logs in, then perhaps he will explain it better.) As I understand it,
MegaPov accepts uv_vectors inside triangle mesh block. But still there
should be something, who generates this uv information.
From MegaPov help file:
=================8<===8<====================================
I've added a new keyword, uv_vectors. This keyword can be used in
bicubic patches to set the UV coordinates for the starting and ending
corners of the patch. The default is
uv_vectors <0,0>,<1,1> // syntax is "uv_vectors <start>,<end>"
If you had another patch sitting right next to this (as happens often
with sPatch or Moray), you could map the exact same texture to it but
use something like
uv_vectors <0,1>,<1,2> // syntax is "uv_vectors <start>,<end>"
(depending on which side of this patch the other is on) so that the two
textures fit seamlessly together.
This new keyword also shows up in triangle meshes (the original kind),
and soon it will be in single triangles, too. Inside each mesh triangle,
you can specify the UV coordinates for each of the three vertices
uv_vectors <uv1>,<uv2>,<uv3>
This goes right after the coordinates (or coordinates & normals with
smooth triangles) and right before the texture. Now that I think about
it, I could maybe make the syntax a bit more flexible (allow you to
interchange "uv_vectors" and "texture").
Date: 25 Apr 2000 09:45:16
Message: <3905A163.EF80601@umh.ac.be>
Thanks!
Fabian.
> > Fabian.
> use something like
Date: 25 Apr 2000 10:35:23
Message: <3905ad2b@news.povray.org>
Fabian BRAU <Fab### [at] umhacbe> wrote:
: I don't how you can give u and v values information with mesh
: syntax? But one says that uv_maping work with mesh! So...
  Of course it works, but it can't read your mind to see what is what you
want. You have to tell it that "for this vertex, take the texture from these
texture coordinates" and this for all vertices of the mesh.
  This usually is not made by hand but with a modeller program.
Date: 25 Apr 2000 11:57:59
Message: <3905C07E.E2D26619@umh.ac.be>
Ok I reformulate,
practically, how one can use uv_mapping with mesh/mesh2?
There is a modeller which do this?
Fabian.
Date: 25 Apr 2000 12:28:18
Message: <3905C7F2.380F3D4B@aetec.ee>
Fabian BRAU wrote:
> Ok I reformulate,
Yes, I guess that many modellers do this. I use Rhino (
http://www.rhino3d.com ), export from it to 3DS format and convert with
3ds2pov to pov-ray mesh. Only drawback is that it costs $800 ($195 for
students). (Trial version with 25 saves is free for download)
Perhaps mr. "Linkmaster" Ken has links to other modellers, with which
uv-mapped objects could be created (truespace is one, that I know,
versions 1 and 2 could be downloaded from some magasine site free, IIRC,
but I'm not sure, whether with these versions it is possible, I have
version 4.3 and it is possible to use uv-mapping from it in POV).
