POV-Ray : Newsgroups : povray.unofficial.patches : Help with photons. Can't get rid of bright dots Server Time
23 Mar 2026 07:44:40 EDT (-0400)
  Help with photons. Can't get rid of bright dots (Message 1 to 3 of 3)
Subject: Help with photons. Can't get rid of bright dots
Date: 19 Apr 2000 06:26:20
Message: <38fd89cc@news.povray.org>
I'm trying to make an underwater scene using a heightfield and photons.
There are bright white dots on the heightfield. I can't get rid of them.
I have tried with many combinations of gather and radius, but no avail.
  The funny thing is that if I replace the heightfield with a plane, there
are no white dots.
  What photon settings should I use?
  The scene follows:
#version Unofficial MegaPov 0.4;
#declare UsePlane=no;
global_settings
{ photons
  { //count 100000
    radius 2
    spacing .4
    jitter .4
    media 100
camera { location -z*10 look_at 0 angle 35 }
light_source { <1000,3000,0> 1 }
fog
{ fog_type 2
  distance 30
  rgb <.4,.6,.8>
  fog_offset -4
  fog_alt 10
sky_sphere
{ pigment { gradient y color_map { [0 rgb <.7,.9,1>] [1 rgb z] } }
#if(!UsePlane)
height_field
{ pattern 200, 200
  { hf_gray_16
    granite color_map { [0 rgb 0][1 rgb 1] }
    scale .5
  smooth
  pigment
  { granite color_map { [0 rgb <1,.7,.3>][1 rgb <.8,.5,.1>] }
    scale .5
#else
plane { y,.5 pigment { rgb <1,.7,.3> }
  translate <-.5,0,0>
  scale <100,3,100>
  translate <0,-4,-2>
box
{ <-30,5,-11><30,-4,200> hollow
  pigment { rgbf <.95, .96, 1, .95> }
  normal { bumps 1 scale 1.5 }
  finish { specular .5 reflection .2 }
  photons { target refraction on ignore_photons }
  interior
  { ior 1.33
Subject: Re: Help with photons. Can't get rid of bright dots
Date: 20 Apr 2000 09:05:57
Message: <38ff00b5$1@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote...
> are no white dots.
If you comment out "smooth" in your height field, the white dots go away.  I
don't yet know exactly what causes them.
-Nathan
Date: 20 Apr 2000 09:19:39
Message: <38FF03E2.F5794FD7@chemnet.ee>
If you don't comment out "smooth" and increase scale:
height_field
{ pattern 300, 300
  { hf_gray_16
    scale .8 //<--- changed from 0.5
  smooth
  pigment
    scale .5
then there are a lot less of these white dots.
Antti
