POV-Ray : Newsgroups : povray.unofficial.patches : Transforming an object without transforming its texture Server Time
26 Mar 2026 01:58:48 EDT (-0400)
  Transforming an object without transforming its texture (Message 11 to 18 of 18)
Subject: Re: Transforming an object without transforming its texture
Date: 12 Mar 2000 11:33:04
Message: <chrishuff_99-16018E.11345412032000@news.povray.org>
In article <38CBC0EF.C3BD1DA5@pacbell.net>, lin### [at] povrayorg
wrote:
> Now correct me if I am wrong here but Warp wants the texture to NOT
> translate along with the object. Now if I were to make a complex
> tropical fish with multiple textures I can tell you right now I
> would want my textures to stay where I put them. If you don't you
> will have textures lining up in all the wrong places. With trees
> you might have leaf textures where bark is supposed to be and with
> a fleet of space ships you might have glass where the hull texture
> is supposed to be. I don't understand your examples at all.
With a tree, the leaves would be separate textures from the bark. Moving
the tree without moving the textures would mean that the colors of the
leaves would change, and the bark would be different for each tree, but
they would still look like trees(with nearly identical shapes, but the
different colorations would disguise much of that).
With space ships, glass would have a different texture than the hull
plates. Each ship would have different sets of hull plates and other
features, but each texture would be applied where it is supposed to be.
With fish, the same goes. Different fish would have different patterns
of colors, but the textures would be applied in the same place.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 13 Mar 2000 03:27:10
Message: <38cca65e@news.povray.org>
Precisely.
I found it useful (applying textures *after* certain transforms) in making a
variety of wood planks, all consisting of the same 'type' of wood, marble,
what have you, but this is absolutely essential to camoflage patterns and
the like.
  It used to come handy in halo-type flames, as well.
Grim
gri### [at] isonet
Date: 14 Mar 2000 10:48:20
Message: <38ce5f44@news.povray.org>
"Chris Huff" wrote:
> Yes, I want to make many(Like 100 or so) different versions of it, each
> scaled, rotated, and with a matrix transform in addition to being
> translated. Can you do that too? :-)
A workaround : make your object a macro like #macro
myObject(currentTransform).
I hope this helps,
Philippe
Date: 14 Mar 2000 20:25:08
Message: <chrishuff_99-9241A2.20270214032000@news.povray.org>
In article <38ce5f44@news.povray.org>, "Philippe Debar"
> I hope this helps,
Yes, that is possible, and I often do my objects this way so I can
incorporate other randomized elements for a little more realism. But a
way to translate an object and not it's texture, some kind of flag for
the transform {} blocks, would still be useful sometimes. It would
require you to use the transform {} block to enclose your
transformations, but this might be a good idea anyway...and it would
only be for a few small cases that you would want to do this.
Chris Huff
Date: 16 Mar 2000 03:18:37
Message: <38d098dd@news.povray.org>
As I wrote : a workaround.
Date: 18 Apr 2000 10:24:35
Message: <qqmaeircwrg.fsf@schlatt.fmi.uni-konstanz.de>
Chris Huff <chr### [at] yahoocom> writes:
> > I hope this helps,
IMHO it would be more "clean" to introduce a way to invert a transformation.
As far as I know, the inverse matrix is already calculated internally.
(The struct TRANSFORM has the two members "matrix" and "inverse".)
So, the implementation should be easy.
Then you would get the desired effect like this:
#declare Trans = transform { translate .. rotate .... }
#declare InvTrans = transform { invert_transform Trans }
object { ... texture { ... transform{InvTrans} } transform {Trans} }
Just my 0.02 Euro
http://thomas.willhalm.de/ (includes pgp key)
Date: 18 Apr 2000 17:27:30
Message: <chrishuff_99-1739C1.16301818042000@news.povray.org>
In article <qqm### [at] schlattfmiuni-konstanzde>, Thomas
> transformation.
While I agree that something like this would be useful(as a matter of
fact, I have been considering it for my next project), I don't see how
it helps in pretextured objects. If your example is used, you don't even
need inverse_transform, you could write it like this:
object { ... transform {Trans} texture { ... } }
However, many times, an object is composed of many parts with different
textures, your solution requires that everything be #declared and
assembled separately.
Really, I think a way to access CSG sub-objects and their
textures/transformations/interiors/flags through a dot notation would be
the best and most elegant way to do things. MegaPOV has taken some steps
toward this already. Some way to attach variables and macros to objects
would also be very useful.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 19 Apr 2000 04:00:04
Message: <qqmvh1ecygr.fsf@schlatt.fmi.uni-konstanz.de>
> > transformation.
> I don't see how
You're right. Perhaps I should use more pretextured objects, since I didn't
really understand the problem...
