POV-Ray : Newsgroups : povray.unofficial.patches : REQ: Improved media efficiency Server Time
2 Nov 2024 05:20:39 EDT (-0400)
  REQ: Improved media efficiency (Message 1 to 8 of 8)
Subject: REQ: Improved media efficiency
Date: 6 Mar 2000 11:14:52
Message: <NTnDOAGSBzHHoh5uC0Ey4azKVFd+@4ax.com>
Is it possible to speed up the media calculations where multiple
densities are involved? More precisely, can some type of bounding be
used with finite density patterns such as spherical, cylindrical or
planar? This would be especially beneficial for smoke, fire and steam
modelled with multiple spherical "puffs".
I imagine the process would be something like this (pseudocode):
For a given ray R, media densities D[n] bounded by B[n] and contained
in C, and time parameter t (for the ray equation):
Find_All_Intersections (R, C, t);           // t is an array
for (i=0; i<n; i++)
{ Find_All_Intersections (R, D[n], t1);     // t1 is an array
  if (t1)                                   // Intersection found?
  { I = Find_Overlapping_Intervals (t, t1); // I is an array
    foreach (I) Take_Media_Samples (I);
If something like this is already implemented, for example in the blob
pattern, please let me know.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Subject: Re: REQ: Improved media efficiency
Date: 6 Mar 2000 13:40:23
Message: <chrishuff_99-36FA7A.13420506032000@news.povray.org>
In article <NTnDOAGSBzHHoh5uC0Ey4azKVFd+@4ax.com>, Peter Popov
I don't think it would be possible with spherical or cylinderical, since
they are basically bounded onion and wood patterns. Planar would be a
kind of bounded gradient. For example, with spherical, you would have to
get the distance from the origin, and only evaluate the spherical
pattern if the distance is below a certain value. However, the spherical
pattern just returns the distance from the origin if it is below that
value, so the "bounding" would be redundant and would actually slow
things down(you would have to calculate the distance and a conditional
an additional time).
If you have a slow rendering pattern(like proximity) and you want to
confine it to a certain area, you might want to try "bounding" it with
the object pattern. That pattern only uses the inside-outside test, so
it is pretty fast for most primitives.
I didn't really understand the pseudo code you showed, but I don't
understand the media code very well either.
The blob pattern and pigment are very un-optimized. All of the
components are tested for each evaluation point. I plan to add a list to
each component which contains pointers to the components it interacts
with in order to fix this problem, but I haven't had time yet. It is
still pretty fast as-is, though.(that is one reason I haven't bothered
to optimize it)
Chris Huff
e-mail: chr### [at] yahoocom
Subject: Re: Improved media efficiency
Date: 6 Mar 2000 16:08:01
Message: <38c41e31@news.povray.org>
Peter Popov <pet### [at] usanet> wrote...
Using multiple media container objects, one for each density, to bound the
media should produce the desired result.  Remember to increase the max trace
level if you try this suggestion.
-Nathan
Date: 6 Mar 2000 17:15:45
Message: <VCvEOJ7qtG0JsT5D+iOe+zkaeq0r@4ax.com>
On Mon, 6 Mar 2000 16:04:08 -0500, "Nathan Kopp" <Nat### [at] Koppcom>
This solution is *extremely* slow, especially when a couple of
hundreds or more objects are involved (like in dense smoke). Blobs
turn out to be the best in this case (and speed comparisons prove it)
but the problem with testing every sample against every density
remains.
Take a spherical density. Why test 30 samples against it if the ray
doesn't pass through its bounding volume at all? Intersect the ray
with the bounding object of the density, and if and only if there are
intersections (they will be exactly two) go on with shooting the
samples. The two intersection points will actually be samples of
density 0 so they can be cached and used in the calculations so no
redundant work will be done.
I think this will speed up rendering for any value of samples/pixel
greater than 2.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 7 Mar 2000 12:12:37
Message: <38C538FF.EE8B846C@reading.ac.uk>
Peter Popov wrote:
[snip]
> greater than 2.
> Peter Popov
> pet### [at] usanet
> ICQ: 15002700
I think this would _really_ foul up some of my cloud techniques where I
use
	density { spherical colour_map {[0 rgb 1][cloudBase rgb 0]} }
or
	density { spherical frequency -1 colour_map { ... } }
and similar constructs.
Does nobody else use blend maps in density?
Well, just my thoughts ...
	Mike Andrews.
Date: 7 Mar 2000 16:46:48
Message: <pXfFOFjSyKBZ7y7DdmDTs=D7V2zV@4ax.com>
On Tue, 07 Mar 2000 17:14:39 +0000, Michael Andrews
Foul up?
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 8 Mar 2000 12:05:20
Message: <38C688CE.9C25FF1A@reading.ac.uk>
Sorry - colloquial usage meaning roughly 'make not work properly' in
this context.
> Foul up?
> Peter Popov
> pet### [at] usanet
> ICQ: 15002700
Date: 8 Mar 2000 14:13:15
Message: <aKXGOCrDjoQAo0UkCRcH1tV7=ZI+@4ax.com>
On Wed, 08 Mar 2000 17:07:26 +0000, Michael Andrews
>this context.
I guessed so, but I still can't see how this approach would affect
whatever densities you're using. All I am suggesting is to test
samples against the relevant densities only. If a ray does not hit a
density's bounding object then nor will any samples along it,
therefore all tests of this ray with this density are just a waste of
rendering time. The output should not be affected regardless of the
addition of 500 samples contributing zilch. IMHO, that is.
Peter Popov
pet### [at] usanet
ICQ: 15002700
