POV-Ray : Newsgroups : povray.unofficial.patches : NURBS primitive? Server Time
19 Nov 2025 21:20:33 EST (-0500)
  NURBS primitive? (Message 1 to 8 of 8)
Subject: NURBS primitive?
Date: 3 Mar 2000 17:21:54
Message: <38c03b02@news.povray.org>
Is there one in MegaPov? if not, how hard would it be to add it?
Dave.
mic### [at] sympaticoca
Subject: Re: NURBS primitive?
Date: 3 Mar 2000 21:02:26
Message: <38C06E3A.9D90DCC4@pacbell.net>
There is not.
Techically it is possible. The question you need to ask is how useful
would it be. NURBS are vary handy in modelling programs for defining
and manipulating complex surfaces. Since POV-Ray is not a modelling
program there will be no way for you to directly change a NURBS surface
and it's usefulness becomes dubious. Triangles can and do accurately
represent the surfaces that NURBS do. Most any capable program that
can model NURBS surfaces can also exported to a format that can be
converted to a triangle based mesh.
Date: 4 Mar 2000 05:13:21
Message: <38c0e1c1@news.povray.org>
>would it be.
Sorry Ken, IMO that sounds like saying "why put in airbags when we already
have seatbelts."
I wouldn't use POV to change the surface just to render it.
The program I use does convert the surface to triangles(and exports to POV
with smooth triangles!) But, in the conversion there is always lost accuracy.
When I render a converted mesh on the edges there is always straight lines
connecting the vertices. This is my problem with it, I don't want to see the
straight lines. Yeah, I could probably crank up the triangle count to minimize
the error but, NURBS are perfectly accurate and I'd much rather get to
construction data into POV so it can calculate the surface. Not to mention the
extreme parse time you have to endure with thousands of triangles.
I checked out a program last night called Lightening3d. It exports NURBS to
POV by converting to bezier patches. Sounds cool. Maybe this is the way that I
could go?
Dave.
Date: 4 Mar 2000 06:21:00
Message: <38C0F1DD.26738120@pacbell.net>
Subject:
        Date:
             Sat, 04 Mar 2000 03:13:51 -0800
             Ken <tyl### [at] pacbellnet>
    Reply-To:
 Organization:
             Tyler Engineering Services
 Newsgroups:
  References:
             1 , 2 , 3
> >would it be.
> have seatbelts."
I have heard many arguments for and against and so far the consensus seems
to favour not including them in POV-Ray. Yours is the first I have heard
where better quality is mentioned. Most argue in favour of smaller file
sizes than their triangle counterparts.
> could go?
Patches have the advantage that you can change the smoothing of the patch
by changing a single parameter. The drawbacks to this is the amount of parse
time needed. The greater the amount of tessellation of the patch needed to
achieve the desired smoothness will add to the time it takes to parse each
patch. File sizes may tend to be a bit smaller but the trade off in file
size will be parsing time.
 For what it is worth I have rendered some enormous mesh files with as
many as a million triangles before and the the parsing time was not in
my opinion all that prohibitive. I have had while loops with much fewer
objects take considerably longer than a huge triangle mesh file takes
to parse and the memory requirement for while loops are much greater.
Date: 4 Mar 2000 07:08:10
Message: <38c0fcaa@news.povray.org>
I take that into consideration aswell.
Really? Though I've never tried it (I probably shouldn't comment) I thought
that with less vertices, less parse time.
Agreed. It's the conversion from NURBS to triangles that's a killer for me.
So, I think i'll poke around a bit and confirm wether that it's too big a
project for me.
Dave.
Date: 4 Mar 2000 10:39:11
Message: <gdb2csc2k8anuof0ohqb25d0akn5oo46f8@4ax.com>
On Sat, 04 Mar 2000 10:15:13 GMT spa### [at] junkmailcom (David Curtis)
  I think Rhino 3d converts NURBS to triangles when exporting to
POV-Ray, also.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 4 Mar 2000 10:42:25
Message: <38C12EDD.B4CD202F@pacbell.net>
> POV-Ray, also.
True. Simon de Vet uses Rhino quite a bit these days and it's output
is very good even in mesh format. I am sure it has a lot to do with
the quality specified at export time as to how smooth the final object
will be.
Date: 4 Mar 2000 10:54:20
Message: <38c131ac@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote...
NURBS, like subdivision surfaces, can be adaptively tesselated at
render-time.  This allows very high quality using very little memory at the
cost of slower render speeds.  Intelligent caching would probably help with
the speed problem.
-Nathan
