POV-Ray : Newsgroups : povray.unofficial.patches : Megapov 0.4 renders dark? Server Time
29 Mar 2026 21:02:34 EDT (-0400)
  Megapov 0.4 renders dark? (Message 1 to 3 of 3)
Subject: Megapov 0.4 renders dark?
Date: 3 Mar 2000 16:34:40
Message: <38c02ff0$1@news.povray.org>
one of my old pov-files renders extremely dark. After replacing the
pvengine-file to the old one, the files render o.k. .
What can be done against this?
Thanks
Hartmut
Subject: Re: Megapov 0.4 renders dark?
Date: 3 Mar 2000 17:35:02
Message: <rjzAOPBilFiGx9fICLfPIGZZ+AvD@4ax.com>
On Fri, 3 Mar 2000 22:32:45 +0100, "Hartmut Wagener"
<har### [at] arcormailde> wrote:
>Hi,
Two things come in mind. Are most of the textures layered? This would
be a major problem in a typical desk layout scene. Another source of
trouble could be radiosity, because it is different in MegaPOV. I
can't really tell more not having seen the source and/or picture.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 3 Mar 2000 17:39:19
Message: <chrishuff_99-E679D9.17405603032000@news.povray.org>
In article <38c02ff0$1@news.povray.org>, "Hartmut Wagener"
> Hi,
Are you using radiosity or layered textures using filter instead of
transmit?
Radiosity went through quite a few changes, the updated version in
MegaPOV fixes some bugs, and removes some of the limits on the old
version. It is also quite a bit faster and gives better results, at
least if you use the right settings. If you just reuse the settings for
the old version, it almost definitely won't come out right.
Also, in MegaPOV, layered textures using filter will filter the layers
beneath them. In the official version, filter and transmit both behaved
like transmit. If you are using filter and want to convert your layered
textures to MegaPOV(and probably POV 3.5, when it is released), just set
the value for filter to 0(or leave it out) and add it's value to
transmit. If your scenes use notation like rgbf <...>, the conversion is
easy, just change "rgbf" to "rgbt".
Note that this is only for layered textures, though. Ordinary textures
work as you would expect.
You can also use the #version directive to use older textures, like this:
#version official 3.1;
...old version texture stuff...
#version unofficial 0.4;
...MegaPOV scene stuff...
but you should probably go to the trouble of fixing your textures.
Chris Huff
e-mail: chr### [at] yahoocom
