POV-Ray : Newsgroups : povray.unofficial.patches : Blurred reflection question Server Time
24 Jun 2026 19:57:15 EDT (-0400)
  Blurred reflection question (Message 1 to 8 of 8)
Subject: Blurred reflection question
Date: 1 Mar 2000 05:32:36
Message: <38bcf1c4@news.povray.org>
I remember someone saying that there's a way to limit the max_trace_level
of blurred reflection calculations in the global_settings. However, I can't
find this information in the documentation.
  What is the syntax and how does it work?
Subject: Re: Blurred reflection question
Date: 1 Mar 2000 07:12:43
Message: <chrishuff_99-375613.07141701032000@news.povray.org>
In article <38bcf1c4@news.povray.org>, Nieminen Juha
>   max_trace_level of blurred reflection calculations in the
>   global_settings. However, I can't find this information in the
>   documentation.
There are two parameters in global_settings:
global_settings {
    reflection_blur_max INTEGER
    reflection_blur_max_adc FLOAT
The reflection_blur_max keyword specifies a max trace level for
blurring. The blurring will only be done below this level, after it is
reached plain reflection will be used. This is similar to the
max_trace_level keyword. The default value is the same as the default of
max_trace_level, I think.
The reflection_blur_max_adc keyword specifies the ADC bailout for
blurring. Blurring will only be done if the ADC weight is less than this
value. This is similar to the adc_bailout keyword. The default should be
1/255. There was a bug with this one, an integer instead of a float was
used for it's variable, but it should be fixed in the latest versions of
MegaPOV.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 1 Mar 2000 11:11:53
Message: <38bd4149@news.povray.org>
It should be documented.
Date: 1 Mar 2000 16:55:22
Message: <38bd91ca$1@news.povray.org>
To all patch authors who have patches in MegaPov: please check the
documentation and make sure that your patches contain full documentation.
Thanks.  Please send me an email if anything needs to be added and changed.
After I've waited a week or two for updates to come in, I'll (hopefully) get
a chance to update the master HTML document with these changes and upload it
again.
-Nathan
Nieminen Juha <war### [at] sarakerttunencstutfi> wrote...
Date: 1 Mar 2000 22:49:42
Message: <slrn8brp9p.v8.ron.parker@parkerr.fwi.com>
It is documented, but I chose to follow the order of the original
docs when laying out the Superpatch docs, so it's documented with
the global settings instead of as part of the blurred reflection
patch.  I'm still not sure that's the wrong approach, but some
overview documentation like the first half of the original docs
would be in order.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 2 Mar 2000 04:38:37
Message: <38be369c@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
:>  It should be documented.
: It is documented
  Why then I can't find it? Searching for "reflection_blur_max" gives no
hits.
warp@sarakerttunen:/usr/oma/warp/docs>grep "reflection_blur_max" megapov.html
Date: 2 Mar 2000 08:15:32
Message: <38be6974@news.povray.org>
>: It is documented
>hits.
Hm.  Well, it _was_ documented, in the superpatch docs.  The last version
of MegaPOV just included those wholesale; I can't seem to find them online
anymore, so now I don't know.
Date: 3 Mar 2000 05:08:00
Message: <38BF8EFE.E7E760AD@umh.ac.be>
I think I have a copy of the old doc at home If this interest you
e-mail me :)
Fabian.
> : It is documented
> hits.
