I got the patterned light sources working, partly working anyway. The
syntax is:
light_source {POSITION
pigment {...}
or
color ...
map_type 0
Either a plain color or a pigment can be used. The map_type keyword
controls how the pigment is calculated, 1, 2, and 3 will be spherical
and cylinderical, where the distance the light has travelled is used for
the z distance. 0 will be "straight mapping", where the pigment is
evaluated at each point without any warping or displacement.
I think it will work with photon mapping, I am not sure though. And the
depth-dependant features don't work yet, so the really interesting
experiments with photon mapping aren't possible. Also, the pigment is
not transformed along with the light source. I think it should be, but I
admit I haven't thought of it much.
I will upload an image to .binaries.images soon.
Chris Huff
e-mail: chr### [at] yahoo com
Subject: Re: First patterned light source image!
Date: 27 Feb 2000 07:58:58
Message: <38b91f92@news.povray.org>
What will be the main use of this feature?
(Btw: My opinion is that povray 3.5 should not be filled with tons of
useless features only because they are "cool"; they only consume space and
make rendering slower (even if not used))
In article <38b91f92@news.povray.org>, Nieminen Juha
Probably the thing it will be used for most often is custom spotlights.
You could control the falloff and the color at each angle precisely. And
with function patterns, you would have a very versatile way of
controlling the light source. Then there was the possibility of using it
as a hologram projector...
The things I find most interesting, like the possibility of using it to
simulate some of the wave behaviors of light, most likely wouldn't get
used very much.
Chris Huff
> used very much.
Oh really ? That was the first thing I thought of (see my reply to your
thread in .images). If I thought of it I am sure that people interested
in such things will also jump to the same conclusion. I have since thought
of 10 - 1 applications for this feature and I have not concentrated on
it for very long. I see a lot of possibilities for it if it don't break
things in the process.
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
> thread in .images).
When I said wave behaviors, I meant things like interference patterns.
While simulating these using ray-tracing would be interesting, I don't
see why anyone would want to use it in an actual scene.
Another idea: simulating different colors of fluorescent paint on an
object. Use the light groups: make a white sphere which interacts with a
patterned light source, and have it be the only thing that light source
affects. Use another light source at the same position, but unpatterned,
and set it to affect everything but the sphere. The sphere will be the
only thing lit up by multi-colored light, which will make it look like
it is covered with several colors of fluorescent paint.
Chris Huff
Date: 27 Feb 2000 10:03:19
Message: <38b93cb7@news.povray.org>
Is there some difference between the patterned light source and a regular
light source with a tiny sphere around it with the desired pattern applied?
In article <38b93cb7@news.povray.org>, Nieminen Juha
> regular light source with a tiny sphere around it with the desired
> pattern applied?
Yes...the patterned light source evaluates a pigment at each point, so
it depends on position instead of just angle to the light source.(And
when I get the mappings working, it will also optionally depend on the
distance the light has travelled.)
Chris Huff
