POV-Ray : Newsgroups : povray.unofficial.patches : My personal wishlist Server Time
2 Nov 2024 05:17:49 EDT (-0400)
  My personal wishlist (Message 1 to 10 of 77)
Subject: My personal wishlist
Date: 24 Feb 2000 15:47:31
Message: <bCW1OIjrykoVBR6nY5iI6VMKZ3UL@4ax.com>
With time I've compiled a list of features I would be happy to see in
POV-Ray. I think it wouldn't hurt if I posted it here.
: df3 tiling, map_type
The density_file pattern would benefit from the possibility to be
tiled in 3D, allowing for easy creation of 3D textures. Mapping types
different from planar would also be great. The former can be achieved
with a set of repeat warps but the seams become visible. The latter
may or may be possible with the proper warp in MegaPOV.
: df3 output, dfc file
The density_file pattern is overlooked by many people because .df3
files are not easily made. It's a pity because this pattern has great
possibilities. If POV were able to directly output to .df3 it would
make life easier for those of us who would like to explore these
possibilities.
My idea is that a new file type triggered by a comman-line (or INI)
option is introduced. An additional depth parameter to output
resolution has to be introduced, too. The program would then sample
the unit cube at width*height*depth points and save the clipped
brightness directly to a density file. Brightness should only be
affected by pigments and media density.
A new type of density file (for example dfc), one that stores
three-dimentional RGB data, would also be of use. The RGB data could
then be used as a default color map for the density_file pattern based
on this file if no color map is specified. Combined with df3 or dfc
output one could easily render a glowing media version of any object,
while preserving the colors.
: strict variable types
I've often fallen victim to implicit type promotion. Also, often I
need to store a large array of boolean data but it is internally
stored as double, taking up 8 or 10 times more memory. What I would
like to see are several variable types optionally assigned to a
variable upon declaration, namely signed/unsigned byte/char and int.
Vector types such as vector2d, vector3d, vector4d and vector5d would
also be useful when memory is an issue, as well as for stricter code.
Fot the non-programmers:
Variable type    Memory used      Range      Applications
unsigned char    1 byte           0 .. 255   counters, indices,
                                             large boolean arrays
signed char      1 byte         -128 .. 127  counters, flags
unsigned int     2 bytes         0 .. 65536  larger counters, indices
signed int       2 bytes     -32768 .. 32767 signed counters,
                                             discrete variables
: promotion
Promoting means converting a value to another type. For example,
#declare Foo = (vector3d) vlength (y)
would assign a vector, namely <1,1,1>, to Foo.
: hash variables
A hash variable is like an array but in addition to an index, each
element has a name by which it can be invoked. For example,
Posters[155] doesn't tell much while Posters[Peter_Popov] does, and
they mean the same to the parser. One useful feature is that they make
passing parameters to a macro much easier.
: media emission/absorption color map
A quick and dirty way to model certain volumetric effects is to map a
color map onto the total emission/absorption along a ray. The syntax I
have in mind is to add an optional color_map block after emission /
absorption.
: patterned turbulence, turbulence_map
Currently it is impossible to vary the turbulence of a pattern. A
blended pattern can not do that. Sometimes one needs to increase
turbulence in certain regions and decrease it in others. An optional
pattern and turbulence_map block after the turbulence keyword could
specify the behaviour of turbulence. More precisely, the value of the
turbulence pattern will be calculated (with the turbulence map in
mind) and will be used to scale the turbulence vector in that point.
: spotlight scale
Non-uniform scaling of spotlights would allow for elliptical
spotlights.
: polygonal spotlight
Although unrealistic, these have their applications. Combined with an
area light, they can be used to simulate, for example, light passing
through a window or keyhole or similar.
: better alpha channel support
The current alpha channel does not take into account media,
transparency and focal blur. There's also a lack of per-object alpha
channel control. For example of one wants to render a focal-blurred
reflective sphere on a checkered floor and then use only the sphere in
a paint program, one would have to make two renders, one for the image
and one for the alpha channel. And sometimes it is just not possible
to isolate the alpha-channel on a per-object basis.
: displacement mapping for patterns
Sometimes a very specific type of turbilence is needed, for example
twisting or waving or similar. A displace warp which takes a pattern
as a parameter and returns a vector based on the color on that pattern
in a point, namely x = r-0.5, y = g-0.5, z = b-0.5, would make such
things possible. Maybe some of the isosurface gurus can do it with
function pigments but I can not.
: chop pieces off with bounding
If a bounding object is smaller than what it bounds, the results are
unpredictable. I think a more logical behaviour would be the one seen
in isosurfaces, i.e. the bounding object should restrict the bounded
object, exposing the intersection surface and texture. Of course, it
would still bound the object for ray-shape intersection tests.
: leave original textures when CSGing
When performing a CGS difference or intersection, any object with a
non-specified texture is assumed to have a black pigment and ambient
0. I think a more reasonable behaviour would be to ignore its texture
and use the texture of whatever object the intersection point is in.
Of course this could lead to "coincident interiors" problems but I
think with proper CGSing they can be avoided.
: seeded randomness for area_light and aa jitter
This one is pretty straight-forward. It would make animation people's
lives easier.
: zero text object thickness
Sometimes the text object is used in a projection that makes it look
2D. This is most often the case with signatures and credits. For these
cases, having the option to only render the front face of the font
(leaving out the extrusion and back face) would decrease render times
and trace level.
: on error do something useful (skip frame etc.)
OK this one I admit is a bad habit I have from my BASIC years :)
Anyway, it could be useful if an on_error {} block could kick in when
needed. For example:
#on_error
  #declare i=0; #declare S=seed(1492); #declare A=array[100]
  #while (i<=100) #declare A[i]=rand(S); #declare i=i+1; #end
  // the above line will generate a 'subscript out or range' error
#do
  #debug "\n"
  #debug "An error occured\n"
: post_interrupt_command=
This would be an INI-only option specifying what shell command to
execute if the render was interrupted by the user.
: Additional BRDF models
I recently used a rendered which supported 11 differend BRDF
(highlights) models. Now that's cool! The authors were kind enough to
share some of their sources with me:
http://www-graphics.stanford.edu/~smr/cs348c/surveypaper.html
http://www.cs.columbia.edu/CAVE/curet/
http://www.ciks.nist.gov/appmain.htm
Some of them have properties very useful for specific tasks, such as
anisotropy (for a brushed metal look).
Well, this is it, for now .If anyone cares to implement anything from
this list, the beer's on me :-)
Peter Popov
pet### [at] usanet
ICQ: 15002700
Subject: Re: My personal wishlist
Date: 24 Feb 2000 21:00:26
Message: <chrishuff_99-DD9497.21014824022000@news.povray.org>
In article <bCW1OIjrykoVBR6nY5iI6VMKZ3UL@4ax.com>, Peter Popov
Maybe something could be added to my object pattern...my proximity
pattern might also benefit from this(compute the density pattern once
using high settings for proximity, then use the density pattern instead
of the proximity).
Where would you get the color data from a CSG with multiple textures?
Just add the color contribution from every object? And you would have to
restrict yourself to the pigment, since the other features(normal,
finish) kind of depend on having a surface.
> : promotion
I have often wished for this. I think the basic types would be:
char
int
float(maybe replace int and float with "scalar"?)
material, media, color_map, texture, etc.
object(all shapes would be of this type)
pattern(I really think patterns should be variable types too)
function(an isosurface function, it might be a good idea to let these be
used in normal code too)
A clearer declaration syntax would be nice too:
#declare VarName = (Type) VariableStuff;
The closing semicolon would be used for all data types, instead of just
for vectors and scalars.
Also, #declare and #local would only be used to create variables. You
could then modify them without these keywords:
#declare MyCounter = (int)0;
MyCounter = MyCounter + 1;
> : hash variables
I think list structures(and maybe tree structures) would also be good
additions. Or at least the ability to add to and insert into an existing
array.(a separate data structure would likely be easier to code and
would have a cleaner syntax)
> : spotlight scale
> spotlights.
And don't forget cylinderical lights.
This is an interesting idea, but couldn't it be done with the
projected_through patch?
This might be a good idea. On the other hand, it would reinforce the bad
habit of using bounded_by as a kind of CSG...(remember that with some
settings POV can override this statement and use it's own bounding)
Actually, I am pretty sure it uses the default texture, which you can
set with the #default keyword. And I think it would be extremely
difficult to determine which object to choose the texture from...what if
the point is enclosed in more than one object? The current behavior of
using higher level textures or per-object textures if defined or the
default texture otherwise seems to make more sense.
> lives easier.
I don't think this is possible. Providing a seed would allow you to
specify the sequence of random numbers used, but you still can't decide
when they are used. If a point gets covered up doesn't need a random
number computed or if something causes a pixel to need more numbers than
it did before, everything get unsynchronized and you end up with the
same "flying pixels" or static.
I will have to look at those sites...
Other features I can think of:
Simple shaders: really just an extended isosurface function capable of
handling vectors and colors. Not necessarily as full-featured as "real"
shaders, but potentially quite useful.
Patterned light_source's: Have the ability to apply a patterned
color_map to a light source, with the option to use ray direction and
depth instead of point position.(which would kind of simulate light
coming through a colored, transparent sphere surrounding the light
source, but with depth)
light_source {blah, blah
   PATTERN
   color_map {...}
   use_depth_for_z on/off
If the "use_depth_for_z"(somebody please come up with a better keyword!)
feature is turned on, the angles of the initial emission from the light
source will be used for the x and y axis, and the distance the ray has
travelled for the z axis. This should make things like interference
patterns possible.(I wonder what this would look like combined with
scattering media and photons!)
Chris Huff
e-mail: chr### [at] yahoocom
Date: 24 Feb 2000 23:48:52
Message: <38b609b4@news.povray.org>
>   PATTERN
>   color_map {...}
My concept of patterned lightsources would look like this:
light_source {Pos 1}
sphere {0,1 pigment {Blah with filter in some places} scale .0001 translate
Pos}
This would make the sphere dissapear with antialiasing, and would "pattern"
the lightsource, right?
PS: Credits to Chris Colefax for this method which was passed on to me.
Date: 25 Feb 2000 03:17:02
Message: <38b63a7e@news.povray.org>
mmmmm. Sounds interesting
Isn't that better done with clipped by? Or do you want to merge the two?
That would make my life SO much easier. Difficult to
implement though (Think of the following:
difference {
 union {
  sphere {
    <0,0.5,0>,1
    pigment {Red}
   sphere {
    <0,-0.5,0>,1
    pigment {Blue}
  box {
   <0,-2,-2>,<2,2,2>
What colour should the overlapped area of the spheres be?
Red, Blue or Purple?
Another I would like :
 The ability to layer a texture over a complex CSG when each
part has its own texture (If this is possible without using two copies of
the object, please
let me know)
union {
  object {A texture {A}}
  object {B texture {B}}
  texture {PartiallyTransparentTexture layered}
The last texture should be layered over the others, instead
of just applying to objects without a texture.
Gail
* gsh### [at] monotixcoza              * ERROR: COFFEE.COM not found  *
* http://www.rucus.ru.ac.za/~gail/ * Insert cup and press any key *
* Definition of an upgrade: Take the old bugs out, put new ones in*
Date: 25 Feb 2000 06:48:37
Message: <chrishuff_99-591DC6.06500325022000@news.povray.org>
In article <38b63a7e@news.povray.org>, "Gail Shaw"
That is a good idea, although it would have to be used with a version
switch. Maybe also provide for switching this off for specific objects,
something like:
union {
    no_layer_over {
        object {MyObject1 texture {A...}}
    object {MyObject2 texture {B...}
    texture {C...}
MyObject1 would have texture A, and only texture A. MyObject2 would have
texture B with texture C layered over it. This would be nice if you have
a CSG with dozens of parts and which has one with a different texture.
no_layer_over(again, can someone please come up with a better keyword?)
could act like a kind of union, and contain multiple objects. Perhaps it
could contain the texture for it's objects itself...
Of course, this would need to be controlled by a #version switch,
otherwise nearly every CSG ever done will need to be redone.
Also, remove the limitations on layering patterned textures.
Chris Huff
Date: 25 Feb 2000 06:58:06
Message: <chrishuff_99-4E4173.06593125022000@news.povray.org>
In article <38b609b4@news.povray.org>, "TonyB"
> translate
> Pos}
> "pattern" the lightsource, right?
Not quite...that would give the same result as my method would if it
used a pigment(*) that was the same color along the z axis using the
use_depth_for_z option. Or if you used a radial pattern centered over
the light_source(or any other pattern which goes outward from a point
but doesn't change with distance) with that option turned off.
With use_depth_for_z off, the color of the light at a point would depend
on the color of the pigment at that point. With it on, it would depend
on the starting angle *and the distance the light has travelled*. You
could use a gradient z pattern and turn use_depth_for_z on, and get an
approximation of the wave behavior of light. The angle on the x and y
axis's(axii?) would be used for the x and y values, and the distance the
light has travelled to the evaluation point would be used for z. This
should be doeable, even with photon mapping.
(*)Another thing I forgot, a pigment would be useable as the color for
this light, just the pigment keyword would be unnecessary.
Chris Huff
Date: 25 Feb 2000 07:43:04
Message: <38b678d8@news.povray.org>
Peter Popov <pet### [at] usanet> wrote:
: unsigned int     2 bytes         0 .. 65536  larger counters, indices
: signed int       2 bytes     -32768 .. 32767 signed counters,
:                                              discrete variables
  The integer type should be the default integer type of the system. For
most computers it's 4 bytes.
  Making 2-bytes integers would just slow down the program.
Date: 25 Feb 2000 08:13:05
Message: <38b67fe1@news.povray.org>
: : chop pieces off with bounding
: If a bounding object is smaller than what it bounds, the results are
: unpredictable.
  Nope. They are very predictable. Only a ray hitting the bounding object
can hit the bounded object.
  A bounding box is a bounding box, not a clipping box. The current
implementation is the correct one. It should be documented better to
avoid confusion, but it's correct.
Date: 25 Feb 2000 08:44:59
Message: <38B686BB.BA935F7C@pacbell.net>
The biggest single question I have is what are you breaking by removing
the current restriction. I have a feeling that it is there for a good
reason but not being a coder do not know what that reason is.
Date: 25 Feb 2000 08:56:20
Message: <38b68a04@news.povray.org>
Gail Shaw <gsh### [at] monotixcoza> wrote...
> difference {
>  union {
>   sphere {
>     <0,0.5,0>,1
>     pigment {Red}
>    sphere {
>     <0,-0.5,0>,1
>     pigment {Blue}
>   box {
>    <0,-2,-2>,<2,2,2>
None of those.  The overlapped area should be the color of the box.  The
surface in question could either belong to the box or to the whole CSG, but
it couldn't belong to either (or both) of the spheres.
If the box has not texture and you don't specify one for the CSG, then you'd
get the default texture.
> the object, please
> let me know)
> union {
This could be a very useful feature.  I'd say that you should use a syntax
something like:
union {
  add_layer {PartiallyTransparentTexture layered}
Note that the keyword used is 'add_layer' instead of 'texture'.  I
personally don't like the way that layered textures are currently specified
(it has produced unexpected results for me on many occasions before I looked
at the source code).  Therefore, this is just a quick brainstorm suggestion
(probably not something that I will endorse in the future).
-Nathan
