POV-Ray : Newsgroups : povray.unofficial.patches : Shaders? Server Time
7 Oct 2024 06:25:11 EDT (-0400)
  Shaders? (Message 1 to 10 of 22)
Subject: Shaders?
Date: 7 Apr 2000 08:14:21
Message: <38EDD167.140A0456@aetec.ee>
Hi!
First, current state with my RM SL patch:
So far most of my efforts have gone to implementation of shader
compiler.
I've considerably improved shader compiler from POVMAN version and now
it could compile almost everything from RM 3.8 specification (one of
biggest missing parts is transformation matrixes, others are some
built-in functions), althogh it has several shortcomings and requires
more work and cleanup.
However, now I intend to focus my efforts to implementation of POV-Ray
shading VM (virtual machine), which will interpret compiled code. For
this I'd like to hear (err, read) some opinions:
Which functionality should shader patch have? Easiest would be to allow
only change of color and opacity, i.e. it is like pigment replacement in
texture. Actual color of object is still determined by the light
sources, their position with respect to camera etc, and this will be
calculated by POV-Ray.
Other option would be to use full power of SL and use it to fully
describe object properties i.e. it's final color, as seen on picture
(taking into account ambiency, reflectance, illuminance, diffuse etc),
POV-Ray wouldn't modify it.
This will be more complicated to implement and its integration with
other pov-ray code will be more complicated. E.g.
1. how will SL shaded object interact with photons or media? One
possibility is to use to maximum extent pov-ray texture variables in
shader, but this requires rewrite of RM shaders and I'm afraid, that all
properties could
not be mapped easily between 2 products (RM and POV-Ray)
2. There is need to get information from light sources in order to
implement illuminance loops.
3. Many of shaders use surface derivatives in order to antialias
textures. This means that some reasonable implementation for derivatives
should be created. Ron Parker gave link to paper, which could help
("Tracing Ray Differentials"), but I haven't studied it very much.
(Confession: I'm afraid, that my math ain't good either, so if someone
is willing to help here...)
4. Message passing: some mapping between POV-Ray object attributes and
RM attributes should be made.
For now I've plugged shader's call to the function Compute_Pigment and
added to it some parameters (e.g. normal vector in intersection). This
allows to use some simple shaders e.g. slope or normal dependent
texture, bumps, texture, which depends from intersection position,
opacity modification etc. This accords to the first (easiest) solution.
Is it good enough for use or should I shoot for more complete
implementation? Or can someone propose good alternative between VM and
POV-Ray (i.e. which part of resulting rgb should be rendered by pure-pov
and which part by SL VM)?
For an example output look to article with same header in
binaries.images.
P.S. Considering uv information: for some objects uv mapping is already
created, hopefully for others it will be done as well (Nathan, is
someone working on it?). It would be good, if this follows more or less
RM convention for uv-mapping.
Subject: Re: Shaders?
Date: 7 Apr 2000 08:27:55
Message: <38EDD443.6EEDB9FB@umh.ac.be>
Very interesting,
this could open new door for povray!
I have no idea of how it should be integrated inside pov
but I am quite interested :).
Fabian.
> Hi!
> compiler.
> properties could
> binaries.images.
Date: 7 Apr 2000 09:15:14
Message: <chrishuff_99-28392E.08174307042000@news.povray.org>
In article <38EDD167.140A0456@aetec.ee>, Vahur Krouverk
> compiler.
Well, looks like there is no more need for me to work on my shader
patch(which would have been nothing like RenderMan anyway, it would be
much more limiting. Even if I did get it to do more than solid
colors...).
The way I did it was to implement the shader as a pigment type, like
image_map or my blob pigment patch. That way, you could use ambient 1
diffuse 0 in the finish, and get nothing but the results from the
shader, but you could also add in reflection, etc.
I had planned for my patch to eventually have access to a list of light
source positions and colors, camera position, trace functions, etc.
It might be easier for you to use MegaPOV as a code base, it already has
intersection information passed to Compute_Pigment.
I think implementing it as a pigment type would give the most
flexibility...but I don't really know anything about shaders and
especially not RenderMan shaders.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Date: 7 Apr 2000 09:34:09
Message: <38EDE413.4A09BE60@aetec.ee>
> colors...).
Sorry to disturb your plans...
I did same (i.e. new pigment) here.
Well, RM shading language (SL) has same capabilities and I hope, that my
patch will support this eventually. Time will tell.
I already use it. I don't have code here (at work), so I'm not sure,
what I've changed (this has been couple of months ago, when I patched
POVRay, SL compiler was primary target in the meantime).
Hmm, sounds like good idea.
Date: 7 Apr 2000 13:24:09
Message: <38ee19b9@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote...
Also, using MegaPov as your code base will make the port to POV 3.5 easier.
-Nathan
Date: 7 Apr 2000 16:35:01
Message: <38EE46DA.64228B83@inapg.inra.fr>
> compiler.
This looks very interesting and promising. I don't know much about RM
shaders but if we could plug into free shaders libraries (is there such a
thing by the way ?) this could greatly expand pov's texturing abilities.
Could you give examples of things that could be made possible using shaders
and which are currently impossible (or very difficult) to do with pov or
megapov ? For example, would a "patina" shader be possible ?
G.
Date: 7 Apr 2000 16:39:00
Message: <38EE4547.DEDF30BE@x-press.net>
ooh, renderman shaders in pov *drool*
not sure if it'd be possible, but I'd like displacement shaders...and having
the ability to anti-alias a specific shader would be oh so nice...but if
their is some technical limitation that I am not understanding no biggie
and as for the VM thing, I was kinda thinking the same thing, but more in
regards to the talks I read about pov-ray's (upcomming?) plugin system, I
thought it would be super cool to use a VM for the plugin system....(maybe
in java or C or some other cross platform language)
> Hi!
> compiler.
> properties could
> binaries.images.
Date: 8 Apr 2000 07:28:48
Message: <38ef17f0$1@news.povray.org>
Hi!
I really hope you will finish your patch and add it to megapov..
i ve seen some shaders for non-photorealistic rendering that are very
interesting and almost impossible to adapt to current versions of povray
M
Date: 9 Apr 2000 11:08:13
Message: <38F09D2E.7A8EF907@aetec.ee>
I've thought about this too, but I'm not sure, whether it is easy to
implement. AFAIK, RM tesselates surfaces into micro-polygons (each 1
pixel in size), then performs displacement (and normal calculation) and
shading. I don't know, whether (and how) it would be possible without
tesselation.
> and having
This requires derivative information, and as I wrote, it is under
consideration. I hope to release first test version soon and most likely
it will be without derivative support, hopefully POV-Ray antialiasing
compensates it a little bit.
Date: 9 Apr 2000 11:52:38
Message: <38F0A795.3A3547C9@aetec.ee>
For shader examples look http://www.renderman.org/RMR/RMRShaders.html
for various surface shaders (this is what my patch does).
> megapov ?
Hmm, megapov has many additions, of which I'm not quite aware (haven't
POVed long time) so I could give example, which is invalid ;-) How about
anisotropic surfaces? I don't think, that it is supported by megapov. I
try to create number of various examples, when code is evolved enough.
I guess so, but I'm not sure, that I'm able to do it. Writing shaders in
RM SL is not very easy and requires certain skills. But it is required
for writing POVRay patch too. Hopefully when this patch is released,
then concern of some people, that POVRay gets too bloated, will decrease
