POV-Ray : Newsgroups : povray.unofficial.patches : How many lines of code: eliminate plateaus in noise3d by interval change Server Time
1 Jul 2025 05:54:25 EDT (-0400)
  How many lines of code: eliminate plateaus in noise3d by interval change (Message 11 to 18 of 18)
Subject: Re: How many lines of code: eliminate plateaus in noise3d by interval change
Date: 22 Mar 2000 04:25:56
Message: <38d891a4@news.povray.org>
TonyB <ben### [at] panamac-comnet> wrote:
: But, you (programmers) have always said that you could add something for
: backward compatibility. Why don't you just fix it and add a #version thingy
: to use the old noise?
  That's not always a good solution. If you want to use the texture in
a newer scene, you wouldn't be able to use new features.
Date: 22 Mar 2000 06:33:52
Message: <chrishuff_99-24E91A.06355822032000@news.povray.org>
In article <38d891a4@news.povray.org>, Nieminen Juha
Not necessarily, you could keep the old noise functions and have the
parser use them or their replacements depending on what the #version is
set to at the time of parsing. For example, internally there would be
two bozo functions, one for old versions and one for newer versions.
They would both be very similar and would use the same keyword, just the
new one wouldn't have plateaus, and they would be chosen depending on
the #version value.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Date: 22 Mar 2000 06:35:53
Message: <chrishuff_99-5E0538.06375922032000@news.povray.org>
In article <38d87425@news.povray.org>, "Gail Shaw"
<gsh### [at] monotixcoza> wrote:
> Would that also remove the plateaus from the bozo pattern?
If it just modifies the noise function(which it sounds like it does, I
don't know how else it would fit into 7 lines), it would fix the bozo
pattern.
> * Document program code? Why do you think it's called code?        *
Can't really argue with that reasoning...
Date: 22 Mar 2000 10:20:25
Message: <38d8e4b9@news.povray.org>
Is this the first time you put up your whole name? I hadn't noticed it until
now, if you had put it up before. Cool name. Do your friends call you CJ, or
Chris?
Date: 22 Mar 2000 15:41:10
Message: <chrishuff_99-D863CF.15431622032000@news.povray.org>
In article <38d8e4b9@news.povray.org>, "TonyB"
It probably is, although it might be mentioned somewhere on my web page.
I don't use my middle name much.
> I hadn't noticed it until now, if you had put it up before. Cool
> name. Do your friends call you CJ, or Chris?
I usually go by Chris. I don't think many of my friends even know what
my middle name is.
Online, I usually just go by Chris Huff or Chris H, and especially on
this server(which seems to have a large number of other people named
"Chris"), it is a good idea to indicate *which* Chris you are talking
to/about.
Date: 23 Mar 2000 00:36:42
Message: <I6zZOBAv1WjJe=baC1lh9jWOUq7z@4ax.com>
On 21 Mar 2000 10:26:24 -0500, ron### [at] povrayorg (Ron Parker)
wrote:
>On Tue, 21 Mar 2000 08:17:07 -0500, Greg M. Johnson wrote:
>>How *hard* would it be to "fix" pov to eliminate the plateuas that exist
>>in the noise3d function?
>It's not a question of how hard it would be, it's a question of how many
>scene files it would break.
On the other hand, how many scene files have already been "broken"
(ruined) by the current implementation? Also, how many more scene
files must suffer from this bug before it is corrected?
Later,
Glen Berry
Date: 23 Mar 2000 19:38:01
Message: <y7jaOBW7WG0kYzIQixjKqyDKLiCd@4ax.com>
On Wed, 22 Mar 2000 10:18:15 -0500, "TonyB"
>Chris?
I don't think any guy would want to be called CJ. Or don't they show
Baywatch down there? :)
Peter Popov ICQ : 15002700
Date: 23 Mar 2000 20:27:47
Message: <chrishuff_99-CE4B05.20295523032000@news.povray.org>
In article <y7jaOBW7WG0kYzIQixjKqyDKLiCd@4ax.com>, Peter Popov
I have never had anyone call me that, like I said, I don't use my middle
name much. I don't think I would like it much...
