Hello,
someone can give me an explication for this parameter:
pretrace_start, pretrace_end (I know this was already in
megapov 0.3 etc... but I didn't find any good explaination about it).
How this paramater affect the result etc...
Thanks
Fabian.
This is how I have understood it:
When doing radiosity calculations povray stores color values in a spatial
tree. It also reads the spatial tree to see if there was already a value
calculated for a point in space near to the current one (if it's close
enough, then it just takes it and doesn't have to calculate it).
If there are many pre-calculated values in the tree, then the final pass
doesn't have to calculate so many radiosity values and it's faster and
more accurate. For the same reason the second pre-trace pass will be faster
and better than the first one, and so on.
The more the pre-trace passes, the faster and more accurate the final
render (but also the slower the pre-trace stage).
