POV-Ray : Newsgroups : povray.unofficial.patches : Suggestions for MegaPov Server Time
29 Sep 2024 21:25:01 EDT (-0400)
  Suggestions for MegaPov (Message 1 to 6 of 6)
Subject: Suggestions for MegaPov
Date: 14 Feb 2000 23:05:55
Message: <38A8D08B.BF35F77E@hotmail.com>
For height feilds would it be possible to use bicubic patches to smooth
it out esp for low res ( spatial & colour ) height feilds in the
foreground of an image
using background { rgba <1,1,1,1>} (a for alpha) when outputing an image
should (if the selected file format supports it) add an alpha channel to
the image - this would be useful
Post-process - add a lens flare - I saw this done in a separate program
(command line) somewhere in the pov-links/Kens links - Not to take
anything from NKFlare & Colefaxe's lens include
a question - Is the post-process legal for submissions to the IRTC
Download 'us-ascii' (1 KB)
Subject: Re: Suggestions for MegaPov
Date: 15 Feb 2000 01:14:17
Message: <38a8eeb9@news.povray.org>
In article <38A8D08B.BF35F77E@hotmail.com> , Pabs <pab### [at] hotmailcom>
Alpha channel output is already support by POV-Ray using the "+UA" switch.
See section "File Output Options" in the official documentation for details.
       Thorsten
Date: 15 Feb 2000 01:27:20
Message: <38a8f1c8@news.povray.org>
"Pabs" <pab### [at] hotmailcom> wrote in message
news:38A8D08B.BF35F77E@hotmail.com...
Guess that would take a rewrite of the height_field.
rgbt (or transmit) already goes into the alpha channel but background is another
matter I suppose.  Also, render a fisheye lensed camera scene and the unrendered
parts outside the field of view will be fully transparent in the alpha channel.
That probably needs to be changed I would think.
Guessing you might mean Sparkle but not sure, that does a pixel color check
grows a white flare object of the proportionate size to the area of lightness.
I think so anyway.  Nathan has said he might someday add flares if he can or
will.
Maybe the 'focal_blur' and 'depth' would be considered okay for IRTC since they
use the scene 3D info, not so for the 'soft_glow' apparently but if scan-line
renders can be submitted then why not any of those?
Disclaimer: be aware that the person saying all of this might not be of sound
mind... or at least not knowledgeable enough to say anything.
Hey! I resent myself saying that about myself!  No I don't.  Yes I do.
Date: 15 Feb 2000 07:00:45
Message: <chrishuff_99-FCA532.07015515022000@news.povray.org>
In article <38a8f1c8@news.povray.org>, "Bob Hughes"
It could be done with a macro, using eval_pattern(), eval_pigment(), or
trace() to calculate the height for each point. You might not get the
memory advantages of a height field(*)...but that wouldn't be a problem
if there is only one of them in a scene.
(*)Another idea, make bicubic patches act like meshes, so pointers to
the patch are used instead of copies. Or maybe a "store_references"
aspect for all objects, which controls the way they are copied. Maybe
for POV-4.0?(It might be too difficult/ugly to implement in the current
C source, but should be quite easy in C++)
Chris Huff
e-mail: chr### [at] yahoocom
Date: 15 Feb 2000 10:35:51
Message: <38a97257@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote...
This would be more memory efficient, to be sure.  It might be slower (due to
more render-time transformation calculations), but if done properly, it
shouldn't be too bad, and the option could exist to expand all references
for speed reasons if the computer has lots of memory.
-Nathan
Date: 15 Feb 2000 15:55:49
Message: <chrishuff_99-0E72FC.15565915022000@news.povray.org>
In article <38a97257@news.povray.org>, "Nathan Kopp" <Nat### [at] Koppcom>
> (due to more render-time transformation calculations), but if done
> properly, it shouldn't be too bad, and the option could exist to
> expand all references for speed reasons if the computer has lots of
> memory.
Hmm, although the transformations would slow things down slightly, they
might prevent some people from having to go to virtual memory, so it
could in some cases be faster.
Now that I have thought about it more, it shouldn't be too hard to
implement even in the C source. Just add a flag to each object
specifying the storage method, maybe add a counter of objects using the
data, and make some small modifications in the functions which copy and
destroy the objects. Make sure the data isn't destroyed if an object is
using it. And of course modify the object data structures and the code
which uses them so they can share data.
I don't really have the time to look at the source right now, though, so
I am just going by memory...I am too busy with my particle simulator, a
couple other potential projects, learning the MacZoop application
framework, thinking of learning more Java, and of course school. :-(
I am beginning to wish days could have 36 hours...although I am sure
school would just take more of them...
Chris Huff
