POV-Ray : Newsgroups : povray.unofficial.patches : In search of plateau-free noise Server Time
2 Nov 2024 07:26:50 EDT (-0400)
  In search of plateau-free noise (Message 1 to 4 of 4)
Subject: In search of plateau-free noise
Date: 6 Feb 2000 18:51:33
Message: <389e0905@news.povray.org>
In p.u.p,  we were discussing options for getting a plateau-free noise
function for pov.  I was experimenting with the pattern-based pigments
in isosurfaces and wonder if I found something in dents.
The "dents" pattern below almost looks plateau-free, although not
exaclty "smooth" as the ideal function I'm looking for would have.
"Bumps" has plateaus.  So how are dents and bumps different?
 [This same text and actual images in p.b.i].
//           switch to                         DENTS here
#declare yikes=function{pigment {bumps scale 30}}
#declare funk=
isosurface{
        function{
              y/100+yikes(x,y,z)/2}
              sign 1
              accuracy 0.01
              threshold 1
           clipped_by
           { sphere{0,250}}
Subject: Re: In search of plateau-free noise
Date: 6 Feb 2000 19:06:38
Message: <chrishuff_99-D8B348.19073506022000@news.povray.org>
In article <389e0905@news.povray.org>, "Greg M. Johnson"
While bozo, spotted, and bumps simply call Noise(), the function for
dents seems to just return the cube of Noise().(I really don't see how
this could be useful when poly_wave and bozo(or bumps, or spotted) could
give the same result...I assume it comes from a version which didn't
have pattern waveforms yet)
Probably the reason it appears to not have any plateaus is the way it
curves near the edge of the plateau. The action of cubing the value
might make it curve so the flat area is almost indistinguishable.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 6 Feb 2000 19:29:41
Message: <389E11D8.71DE3F9D@pacbell.net>
Chris Huff wrote:
> (I really don't see how this could be useful when poly_wave and bozo
>(or bumps, or spotted) could give the same result...I assume it comes
> from a version which didn't have pattern waveforms yet)
The only normal patterns and modifiers that were available in POV-Ray v2.2
are as follows -
        5.4.2   NORMAL
                5.4.2.1 Bumps
                5.4.2.2 Dents
                5.4.2.3 Ripples
                5.4.2.4 Waves
                5.4.2.5 Wrinkles
                5.4.2.6 Bump_map
                        5.4.2.6.1   Specifying a bump map.
                        5.4.2.6.2   Bump_size
                        5.4.2.6.3   Use_index & use_color
                        5.4.2.6.4   The "once" option.
                        5.4.2.6.5   The "map_type" option.
                        5.4.2.6.6   The "interpolate" option.
                5.4.2.7 Normal Modifiers
                        5.4.2.7.1   Turbulence
                        5.4.2.7.2   Frequency and Phase
                        5.4.2.7.3   Transforming normals
Date: 7 Feb 2000 07:17:06
Message: <389EB6E8.7FA9850A@my-dejanews.com>
Ah yes, the cube! It's so obvious now in comparing the two objects........
> Chris Huff
> Web page: http://chrishuff.dhs.org/
