POV-Ray : Newsgroups : povray.unofficial.patches : Speeding up blurred reflection Server Time
19 Nov 2025 21:08:11 EST (-0500)
  Speeding up blurred reflection (Message 1 to 4 of 4)
Subject: Speeding up blurred reflection
Date: 2 Feb 2000 05:27:31
Message: <38980693@news.povray.org>
Blurred reflection can be extremely slow. For example, the following
scene will take _FOREVER_ to calculate:
#version unofficial MegaPov 0.4;
global_settings { max_trace_level 6 }
camera { location <-2,1,-4> look_at 0 angle 60 }
light_source { <3,4.9,-4> 1 }
box
{ -5,5 inverse
  pigment { rgb <.3,.5,1> }
  finish
  { specular .5
    reflection 1 reflection_blur .04 reflection_samples 20
  It shouldn't be strange, however, since povray is calculating an amazing
amount of 3200001 rays per pixel!
  Lowering max_trace_level will help (for example with max_trace_level set
to 3 it will calculate only 401 rays per pixel). However this is not a good
solution if there are transparent objects in the scene.
  There should be a max_trace_level that could be applied to the blurred
reflection. After it's reached, only regular reflection would be used
(I think that the blurred refraction patch uses this method). Also a
adc_bailout value for blurred reflection could be good.
  A more advanced method could be something like: The first reflection is
calculated with all the specified 20 samples, the second reflection could
use only 10 samples, the third 5 samples, and so on. The decrease factor
could be user-specified.
Subject: Re: Speeding up blurred reflection
Date: 2 Feb 2000 07:48:53
Message: <chrishuff_99-0F2544.07494302022000@news.povray.org>
In article <38980693@news.povray.org>, Nieminen Juha
Both of these are already implemented. They are reflection_blur_max and
reflection_blur_max_adc, in global_settings. My transparency patch has
similar controls.
I have been thinking about this, something like a depth_blur_scale or
something. I don't think it would be terribly useful, though, and
setting the max blur level to 2 or 3 is usually enough.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 2 Feb 2000 10:56:45
Message: <389853bd@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote:
: Both of these are already implemented. They are reflection_blur_max and
: reflection_blur_max_adc, in global_settings. My transparency patch has
: similar controls.
  I didn't see it in the documentation.
Date: 2 Feb 2000 11:21:43
Message: <38985A69.BE622775@umh.ac.be>
Actually, this was in the previous doc on the Nathan site (superpatch
doc) BUT not at the same place that doc on blurred reflection:
reflection_blur was in texture part of the doc and reflection_blur_max
was in the global settings part. So I think that Nathan didn't see this
or forget to add it. This is a hard and ennoying job to do doc :)! So
I don' t blame Nathan :)!
Fabian.
> : similar controls.
