POV-Ray : Newsgroups : povray.unofficial.patches : Pigment patterns in an isosurface? Server Time
1 Apr 2026 02:09:09 EDT (-0400)
  Pigment patterns in an isosurface? (Message 11 to 13 of 13)
Subject: Re: Pigment patterns in an isosurface?
Date: 4 Feb 2000 16:28:22
Message: <slrn89mh35.v8.ron.parker@ron.gwmicro.com>
On Fri, 4 Feb 2000 12:50:49 -0500, Nathan Kopp wrote:
>This has been discussed in the past (with no resolution found).  The problem
>is that POV's Noise() function is not "correct".  A solution has been
>proposed which would, unfortunately, not be completely backwards compatible.
>My personal preference would be to provide an option to allow backwards
>compatibility but by default use a "correct" Noise().
Why does noise3d() clamp?  Is there some reason it should?
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 4 Feb 2000 16:32:29
Message: <389b456d@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote...
problem
compatible.
The big problem is that it doesn't clamp correctly.  Or, rather, it doesn't
scale the output properly before it clamps.  Honestly, I don't think it
really is that necessary that it clamps, either.
-Nathan
Date: 4 Feb 2000 18:35:25
Message: <389B6163.50A2026A@my-dejanews.com>
Stepping above my area of expertise:
    Wasn't the idea that instead of using an interval of 0 to 1, it went from
-0.5 to 0.5?
> problem
> compatible.
> -Nathan
