POV-Ray : Newsgroups : povray.unofficial.patches : MegaPov 0.4, macros trouble Server Time
20 Mar 2026 00:31:30 EDT (-0400)
  MegaPov 0.4, macros trouble (Message 11 to 20 of 30)
Subject: Re: MegaPov 0.4, macros trouble
Date: 1 Feb 2000 20:35:37
Message: <389789e9@news.povray.org>
david sharp <dsh### [at] interportnet> wrote...
> Thanks much. Converting scene file cr-lf's  to lf's 'fixes' the
> FastMacroPatch.
> (that is, lets the troublesome macros run).
> What is it that the FastMacroPatch does that other fseek/ftell dependent
> stuff in POV doesn't?
Not much different.  Part of it is to use ftell twice to determine the
length of the macro.  But the problem is that fread() reads a single byte
for CR+LF (converts two to '\n'), but ftell()-ftell() will give two bytes
for CR+LF.  Unfortunately, this does not always happen and is not at all
consistent across operating systems or even compilers on the same OS.
-Nathan
Date: 1 Feb 2000 22:33:14
Message: <3897a57a@news.povray.org>
Nathan Kopp <Nat### [at] Koppcom> wrote in message
news:389789e9@news.povray.org...
I just posted a message (since cancelled), about a fix. But it didn't
really (only coincidentally worked), so if anyone read it, forget it,
please.
Date: 2 Feb 2000 08:27:45
Message: <slrn89gc7g.v8.ron.parker@ron.gwmicro.com>
With all the problems CR/LF/CRLF cause us, why don't we just open the
scene files in binary mode?
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 2 Feb 2000 10:42:32
Message: <38985068@news.povray.org>
In tokenize.c, if I replace Fopen_Ungetc() with the following code,
MegaPov works on MS-DOS style scene files.
This is an inelegant way to go about it, but arf.
#ifdef __GO32__
static void Fopen_Ungetc (DATA_FILE *File, int Ch)
  if(Ch=='\n')
          ungetc ('\r', (FILE *) File->Data);
  ungetc (Ch, (FILE *) File->Data);
#else
#endif
Date: 2 Feb 2000 12:10:01
Message: <389865F7.554A6048@geocities.com>
Probably because if you open a file as binary, you'd have to manage the
conversion of CRLF to LF yourself, whereas opening in text mode handles some
of it for you. Especially for DOS/Windows programmers, opening in text mode
to get CRLF converted to LF is quite handy. Hmmm... I wonder if on the Mac it
converts the simple CR to LF?
Anyway, I think that's why. But I think that the why-not would probably
outweigh the why. Of course, my personal preference would be to read and
normalize EOL's and also to Unicode (UTF-8 or UTF-16) and make sure the
reading routines were written to handle this. Perhaps step one would be to
get away from direct dependence on ftell and isolate that in a buffer layer
that opens files in binary mode and handles EOL conversions. Step two could
be to then make this layer return Unicode and to handle that properly.
Once that was done, the program could handle all sorts of languages without
having to actually process in those charsets. Also, that could make things
work for people who don't have that specific language as their OS. That is, a
Japanese user could send me a Japanese POV-Ray source file and even though I
would be unable to read it, I could render it and get the exact same results
as the Japanese user did.
But... opening files in binary mode and handling the CRLF issues (even the
messed up CRCRLF that you get on Windows) probably would be best.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Date: 2 Feb 2000 12:16:19
Message: <38986771.FAF31874@geocities.com>
> #ifdef __GO32__
>   if(Ch=='\n')
> #else
> #endif
Could I bug you to try to always use braces, even for single line
bodies?
  if(Ch=='\n') {
As opposed to some things that are just a matter of style ( e.g. where
you decide to place them), always using braces even for single line
bodies is a good idea that helps prevent problems. Sometimes it's
possible to write logic incorrectly and miss it due to misleading
indention, but braces would catch that. Also, there are times when what
you thought was a simple function might actually change to be a
multi-line macro... and if so, BOOM! And many more details, but I'll
hold those for later discussion, if needed.
Date: 2 Feb 2000 12:44:04
Message: <38986ce4@news.povray.org>
> bodies?
It depends on what you mean by 'bug'. If you mean ominous threatening
calls in the middle of the night and renting the apartment upstairs and
installing loudspeakers pointed into the floor, please don't.
Your complaint is one I agree with when dealing with other people's
code, but often leave off  braces myself.
Date: 2 Feb 2000 12:56:57
Message: <slrn89grut.v8.ron.parker@ron.gwmicro.com>
Other than //-comments, I can't think of any POV feature that distinguishes
between newlines and other whitespace, and there are none that care about
multiple newlines (unlike C, where a multiline #define gets messed up by
such things.)  That being the case, CR and LF could each be treated as EOL
characters, and the weird DOS practice of putting both of them on each
line would just be handled like a double-spaced file.  (CRCRLF would be
triple-spaced.)
Date: 3 Feb 2000 03:00:52
Message: <389935b4@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: With all the problems CR/LF/CRLF cause us, why don't we just open the
: scene files in binary mode?
  How does povray read the file? If it reads it one character at a time, then
I think this would be a good solution.
Date: 3 Feb 2000 03:14:41
Message: <389938f1@news.povray.org>
Jon A. Cruz <jon### [at] geocitiescom> wrote:
: Could I bug you to try to always use braces, even for single line
: bodies?
:   if(Ch=='\n') {
:           ungetc ('\r', (FILE *) File->Data);
  Good idea, as long as you don't put the braces that way.
  The opening brace of a block should be at the beginning of the block, not
at the end of the previous line.
