POV-Ray : Newsgroups : povray.unofficial.patches : Mega Photon Bug? Server Time
19 Nov 2025 22:51:41 EST (-0500)
  Mega Photon Bug? (Message 1 to 10 of 22)
Subject: Mega Photon Bug?
Date: 11 Jan 2000 15:05:15
Message: <387b8cfb@news.povray.org>
Find attached a self-documenting scene file which demonstrates Mega POV
crashing while using photon maps.
Eric
http://www.ametro.net/~ericfree
Download 'phot_test2.pov.txt' (5 KB)
Subject: Re: Mega Photon Bug?
Date: 11 Jan 2000 15:13:12
Message: <387B8F6D.A6BFDAF7@pacbell.net>
It crashes here too. MegaPov v0.3 for windows on a win 98 platform..
MEGAPOV caused a stack fault in module MEGAPOV.EXE at 015f:0047cc06.
Registers:
EAX=031b2318 CS=015f EIP=0047cc06 EFLGS=00010206
EBX=031b2594 SS=0167 ESP=031b1ed8 EBP=031b2270
ECX=db58e664 DS=0167 ESI=031b354c FS=3eef
EDX=031b2594 ES=0167 EDI=031b2330 GS=0000
Bytes at CS:EIP:
53 55 56 33 f6 57 56 e8 2e 11 02 00 a1 7c a3 51
Stack dump:
00000000 00000000 00000000 00000000 00000000 00000000
Date: 11 Jan 2000 16:10:03
Message: <387b9c2b@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:387B8F6D.A6BFDAF7@pacbell.net...
I guess I should have specified, too.  v0.3, Win98, P133, 48megs ram, MS
sidewinder joystick, Global Upholstery Co. swivel desk chair with arm rests,
cold Budweiser on the side [the Bud seems to be the least fault-tolerant
part ;-) ].
Eric
"A wise and frugal government, which shall restrain men from injuring one
another, which shall leave them otherwise free to regulate their own
pursuits of industry and improvement, and shall not take from the mouth of
labor the bread it has earned.  This is the sum of good government."
     - Thomas Jefferson
     - First inaugural address, 1801
Date: 11 Jan 2000 16:51:47
Message: <387ba5f3@news.povray.org>
#declare outerDome = merge {
  cylinder {
    <0,baseCylHite-baseCylGrooveY+gap,0>,
    <0,domeHite,0>
    baseCylGrooveR1-gap
  sphere {
    <0,domeHite,0>,
    baseCylGrooveR1-gap+0.01
This appears to be the problem or answer depending on how you look at it.
The additional gap subtraction from before is changed to addition for this part.
Fixes it up just fine apparently.
> Registers:
> Bytes at CS:EIP:
> Stack dump:
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 11 Jan 2000 19:39:27
Message: <387bcd3f@news.povray.org>
"omniVERSE" <inv### [at] aolcom> wrote in message
news:387ba5f3@news.povray.org...
>   cylinder {
>     <0,baseCylHite-baseCylGrooveY+gap,0>,  ****FIRST GAP
>     <0,domeHite,0>
>     baseCylGrooveR1-gap   ****SECOND GAP
>   sphere {
>     <0,domeHite,0>,
>     baseCylGrooveR1-gap+0.01  ****THIRD GAP
> how you look at it.  The additional gap subtraction from
> before is changed to addition for this part.  Fixes it up just
> fine apparently.
I don't understand the problem.  The dome sits in a groove cut into the
base.  The gap variable is used to add a little separation between the
bottom of the dome and the sides and bottom of the groove to avoid
coincident surfaces.  The first gap is added to lift the dome slightly above
the bottom of the groove (baseCylHite-baseCylGrooveY).  The second and third
gaps are subtracted from the outer radius of the dome to provide a gap
between the dome and the outer wall of the groove (baseCylGrooveR1).  The
0.01 added to the sphere is a fudge amount because without it there is a
line visible where the sphere and cylinder meet.
I've just compared the above with my scene file and see that you are
referring to the 0.01 fudge amount added to the radius of the sphere.  I
don't know why, but negating or removing this 0.01 clears up the problem.
Now I'm back to having a line where the sphere and cylinder meet.
Eric
     - Thomas Jefferson
Date: 11 Jan 2000 20:42:06
Message: <387bdbee@news.povray.org>
Seems to be a problem with the 'merge' there instead, so maybe it really is a
bug.
"Eric Freeman" <eri### [at] ametronet> wrote in message
news:387bcd3f@news.povray.org...
> >   cylinder {
> >     <0,domeHite,0>
> >   sphere {
> >     <0,domeHite,0>,
> > fine apparently.
> Eric
>      - Thomas Jefferson
Date: 11 Jan 2000 20:45:31
Message: <387BDD58.DC207403@pacbell.net>
> bug.
Anything that causes the program to crash is a bug and should be brought
to the attention of the proper people. This inculdes invalid page faults
of invalid stack faults which is the case here.
Date: 12 Jan 2000 10:41:23
Message: <387ca0a3@news.povray.org>
Set your max_trace_level lower and it won't crash.  Mine crashes with a
stack overflow when the trace level gets to 168.  Apparantly I am compiling
with a smaller stack size than the official version.  Anybody have thoughts
as to how big of a stack size I should allow?
-Nathan
Eric Freeman <eri### [at] ametronet> wrote...
Date: 12 Jan 2000 13:32:49
Message: <387CC286.9D70172@bahnhof.se>
> -Nathan
HUGE!
<g>
//Spider    --  [ spider@bahnhof.se ]-[ http://darkmere.wanfear.com/ ]
And the devil in black dress watches over
    My guardian angel walks away
Life is short and love is always over in the morning
    Black wind come carry me far away
            --"Sisters of Mercy" -- "Temple Of Love"
Date: 13 Jan 2000 00:32:12
Message: <387d635c@news.povray.org>
Nathan Kopp wrote in message <387ca0a3@news.povray.org>...
As big as the compiler will allow.
Mark
