POV-Ray : Newsgroups : povray.unofficial.patches : Mega Photon Bug? Server Time
17 Jan 2026 19:43:30 EST (-0500)
  Mega Photon Bug? (Message 13 to 22 of 22)
Subject: Re: Mega Photon Bug?
Date: 13 Jan 2000 04:51:09
Message: <387da00d@news.povray.org>
Mark Wagner <mar### [at] gtenet> wrote:
: As big as the compiler will allow.
  Take into account that the program might _reserve_ the space for the stack
at run time. That is, if you set a 100 Megs stack, the program may need
100 Megs of memory for the stack + the memory for the rest of the things.
Date: 13 Jan 2000 08:29:15
Message: <387dd32b@news.povray.org>
Not under win32, as I understand it.  Win32 has two numbers governing stack
size, a reserved amount set aside in the page table at runtime, and a committed
amount that's actually mapped.  As the stack grows, Windows allocates more pages
to it.  Also, for those skilled at hex editing, the reserved and committed stack
space are just numbers in the executable file, so they can be changed rather
easily without recompiling.
The official POV has a reserve/commit of 80000/10000 (hex). Megapov is set to
100000/1000 (hex).  So if this is a stack problem, it would hit the official
version too, though a little higher commit wouldn't hurt megapov in the
performance department.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 28 Jan 2000 20:31:08
Message: <slrn8942q6.adm.sjlen@zero-pps.localdomain>
I also have a crash problem with photons, the problem
isn't so much the photons or the scene, but when it runs
out of memory with MegaPov, the only thing I can do is
physically turn the machine off and on again.
When I run out of mem with official POV, it just gives
me a nice little message saying that it's run out of
memory, so I do something else instead, or make some
changes to the scene. But MegaPov completely freezes
the box, I've tried this about three times, but
Linux doesn't like being turned off like that, so I
havn't tried it recently.  Looking at my sig, it was
in fact five days ago since I tried it.
Info
RH6.0,  MegaPov, over 64M Ram 1G of swap available.
Scene, David Fontain's torus with a disco ball
inside and lots of photons.
Can provide the Pov file if required.
  9:17pm  up 5 days,  5:28,  6 users,  load average: 5.39, 5.24, 5.11
Date: 29 Jan 2000 00:51:54
Message: <38927ffa@news.povray.org>
I didn't change anything about memory handling, so I don't know why this
would act differently than the official version.  Did you compile your own
official version, or download a binary?
-Nathan
Steve <sjl### [at] zero-ppslocaldomain> wrote...
Date: 30 Jan 2000 00:25:27
Message: <slrn897hhm.3ca.sjlen@zero-pps.localdomain>
No, didn't compile, d/l'd the binaries.
my mem looks like this, in units of KBs.
[sjlen@zero-pps pov]$ free -k
             total       used       free     shared    buffers     cached
Mem:         63136      60884       2252      16692       1312      32616
-/+ buffers/cache:      26956      36180
Swap:       989704      32332     957372
When my current render has finished I'll try rendering something in Megapov
that I know runs out of mem in official POV, and then run it again in
Pov and see what happens. (as this scene doesn't use any new Megapov features).
Scene below:
#declare phd=1;
global_settings{
                adc_bailout 0.003922
                ambient_light <1.0,1.0,1.0>
                assumed_gamma 2.2
                max_trace_level 50
                photons{
                        gather 20,100
                        radius 0.1*phd,2,0.1*phd
                        autostop 0
                        //jitter .4
                        expand_thresholds 0.2, 40
#declare Strobe =
#declare TheGap=5;
#declare MaxAng=359;
union{
      #local outerctr=0;
      #while(outerctr<MaxAng)
        #local ctr=0;
        #while(ctr<MaxAng)
          box{
              <-0.1,-0.1,-0.1>
              <0.1,0.1,0.1>
              translate z*-2.085
              rotate <ctr,outerctr,0>
          #local ctr=ctr+TheGap;
         #local outerctr=outerctr+TheGap;
      pigment{Silver}
      finish{
             phong 0.8
             phong_size 50
             reflection 1.0
             specular 1.0
             roughness 0.0001
             ambient 0.0
             diffuse 0.0
object{
       Strobe
       translate<0,5,10>
       scale 0.5
       photons{
               separation 0.01*phd
               refraction off
               reflection on
      translate z*-10
      rotate y*-90
torus{
      10,2
      hollow
      photons{
               separation 0.01*phd
               refraction off
               reflection on
      pigment{ color White }
      finish { ambient 0
              diffuse .1
              reflection .9
              specular 0.01
camera{
       location <0,0,-10>
       look_at <1,0,-10> }
light_source { <0,0,-10> Red
             photons{
                     reflection on
                     refraction off
light_source { <0,0,-10> Green rotate 120*y
             photons{
                     reflection on
                     refraction off
light_source { <0,0,-10> Blue rotate 240*y
             photons{
                     reflection on
                     refraction off
Hope this helps.
  3:43am  up 1 day,  2:12,  4 users,  load average: 2.23, 2.22, 2.13
Date: 30 Jan 2000 02:49:39
Message: <3893ED17.3A149966@kh.rim.or.jp>
Dear Steve san:
I make test your scene file and get report from memory short error.
My application is MPW MrC version(based official mac 3.1g r2).
I set 128MB to application and system vertial memory is on,
(Power mac G3 DT233 memory 160MB VM  set to 320MB).
Report is like this:
Creating bounding slabs.
Scene contains 5185 frame level objects; 0 infinite.
Creating vista buffer.
Creating light buffers...
Creating Photon Maps.
Building Photon Maps.........................................................
Slab building error.
Ran out of application memory; Increase POV-Ray application memory size.
Reclaiming memory
-- [Finish]  File=photonsbug8.pov,Time=00.1.30  4:27:46 PM
POV-Ray Mac Memory Cache Statistics
Cache hits:               25467755   Cache misses:               816
Total calls to malloc:    25468571   Cache hit rate:             99%
Y.Tanabe
Kobe,Japan
> Scene below:
> Hope this helps.
Date: 30 Jan 2000 18:36:50
Message: <slrn898j5m.4d3.sjlen@zero-pps.localdomain>
On Sun, 30 Jan 2000 16:49:46 +0900, Y.Tanabe <tec### [at] khrimorjp> wrote:
>Dear Steve san:
>Reclaiming memory
Thanks, I'll have to wait untill my machine has finished rendering it's current
scene before I try this again.  The current render has been going for more than
30 hours, so I don't want the machine to crash just yet.
  2:31pm  up 1 day, 13:01,  4 users,  load average: 2.29, 2.25, 2.10
Date: 31 Jan 2000 13:57:50
Message: <slrn89bmbs.1d5.sjlen@zero-pps.localdomain>
Right I've now done some extensive experimentation.
I took a scene that will render in Official pov but requires
more memory than I have, so it's just a standard scene with
millions of objects.  In both official and Mega it gives
me a message telling me that it's run out of memory, no problem.
But when I render a scene with photons and it runs out of memory
while creating the photon data the box freezes completely.
I had to go out (yes actually outside the house) today so I set
the render running with xmegapov -Imyscene.pov and left it for
a few hours, it froze, so I thought give it a few hours and it
might sort itself out, but after the screen had cutout I couldn't
even get my display back by pressing the shift key the way I
normally do.  Before losing the screen and after the freeze
the mouse pointer wouldn't move, I couldn't Alt-Ctrl-Fn to another
session, I couldn't Alt-Ctrl-Backspace out of X.
One more thing that I will try is running a scene that has photons,
but runs out of memory before it gets to the point where it starts
to generate the photon data.  I will try this soon, and post the
results in this thread.
  6:37pm  up  4:09,  2 users,  load average: 1.44, 1.22, 1.14
Date: 31 Jan 2000 18:20:26
Message: <slrn89btnh.1ig.sjlen@zero-pps.localdomain>
On a scene that runns out of memory before starting to
generate the photon data the machine doesn't freeze.
  8:53pm  up  6:26,  2 users,  load average: 1.60, 1.52, 2.03
Date: 1 Feb 2000 01:33:00
Message: <38967e1c@news.povray.org>
Steve wrote in message ...
Sounds like a recursive call to Error().  Someone who has a debugger might
want to check this out.
Mark
