Mark Wagner wrote:
> > Anybody have thoughts as to how big of a stack size I should allow?
> As big as the compiler will allow.
...and then a little bit more :)
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
"Nathan Kopp" <Nat### [at] Kopp com> wrote in message
news:387ca0a3@news.povray.org...
> Set your max_trace_level lower and it won't crash.
That fixed it. Which brings me to the effects of the photons on the
scene... but that's a different story.
> Mine crashes with a stack overflow when the trace
> level gets to 168.
167 and it renders fine.
> Apparantly I am compiling with a smaller stack size
> than the official version. Anybody have thoughts as
As big as you can go without having a reason to not go bigger.
Eric
"A wise and frugal government, which shall restrain men from injuring one
another, which shall leave them otherwise free to regulate their own
pursuits of industry and improvement, and shall not take from the mouth of
labor the bread it has earned. This is the sum of good government."
- Thomas Jefferson
- First inaugural address, 1801
http://www.ametro.net/~ericfree
Mark Wagner <mar### [at] gte net> wrote:
: As big as the compiler will allow.
Take into account that the program might _reserve_ the space for the stack
at run time. That is, if you set a 100 Megs stack, the program may need
100 Megs of memory for the stack + the memory for the rest of the things.
Not under win32, as I understand it. Win32 has two numbers governing stack
size, a reserved amount set aside in the page table at runtime, and a committed
amount that's actually mapped. As the stack grows, Windows allocates more pages
to it. Also, for those skilled at hex editing, the reserved and committed stack
space are just numbers in the executable file, so they can be changed rather
easily without recompiling.
The official POV has a reserve/commit of 80000/10000 (hex). Megapov is set to
100000/1000 (hex). So if this is a stack problem, it would hit the official
version too, though a little higher commit wouldn't hurt megapov in the
performance department.
These are my opinions. I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
I also have a crash problem with photons, the problem
isn't so much the photons or the scene, but when it runs
out of memory with MegaPov, the only thing I can do is
physically turn the machine off and on again.
When I run out of mem with official POV, it just gives
me a nice little message saying that it's run out of
memory, so I do something else instead, or make some
changes to the scene. But MegaPov completely freezes
the box, I've tried this about three times, but
Linux doesn't like being turned off like that, so I
havn't tried it recently. Looking at my sig, it was
in fact five days ago since I tried it.
Info
RH6.0, MegaPov, over 64M Ram 1G of swap available.
Scene, David Fontain's torus with a disco ball
inside and lots of photons.
Can provide the Pov file if required.
Steve email mailto:sjl### [at] ndirect co uk
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
9:17pm up 5 days, 5:28, 6 users, load average: 5.39, 5.24, 5.11
I didn't change anything about memory handling, so I don't know why this
would act differently than the official version. Did you compile your own
official version, or download a binary?
-Nathan
Steve <sjl### [at] zero-pps localdomain> wrote...
On Sat, 29 Jan 2000 00:50:22 -0500, Nathan Kopp <Nat### [at] Kopp com> wrote:
No, didn't compile, d/l'd the binaries.
my mem looks like this, in units of KBs.
[sjlen@zero-pps pov]$ free -k
total used free shared buffers cached
Mem: 63136 60884 2252 16692 1312 32616
-/+ buffers/cache: 26956 36180
Swap: 989704 32332 957372
When my current render has finished I'll try rendering something in Megapov
that I know runs out of mem in official POV, and then run it again in
Pov and see what happens. (as this scene doesn't use any new Megapov features).
Scene below:
#declare phd=1;
global_settings{
adc_bailout 0.003922
ambient_light <1.0,1.0,1.0>
assumed_gamma 2.2
max_trace_level 50
photons{
gather 20,100
radius 0.1*phd,2,0.1*phd
autostop 0
//jitter .4
expand_thresholds 0.2, 40
#declare Strobe =
#declare TheGap=5;
#declare MaxAng=359;
union{
#local outerctr=0;
#while(outerctr<MaxAng)
#local ctr=0;
#while(ctr<MaxAng)
box{
<-0.1,-0.1,-0.1>
<0.1,0.1,0.1>
translate z*-2.085
rotate <ctr,outerctr,0>
#local ctr=ctr+TheGap;
#local outerctr=outerctr+TheGap;
pigment{Silver}
finish{
phong 0.8
phong_size 50
reflection 1.0
specular 1.0
roughness 0.0001
ambient 0.0
diffuse 0.0
object{
Strobe
translate<0,5,10>
scale 0.5
photons{
separation 0.01*phd
refraction off
reflection on
translate z*-10
rotate y*-90
torus{
10,2
hollow
photons{
separation 0.01*phd
refraction off
reflection on
pigment{ color White }
finish { ambient 0
diffuse .1
reflection .9
specular 0.01
camera{
location <0,0,-10>
look_at <1,0,-10> }
light_source { <0,0,-10> Red
photons{
reflection on
refraction off
light_source { <0,0,-10> Green rotate 120*y
photons{
reflection on
refraction off
light_source { <0,0,-10> Blue rotate 240*y
photons{
reflection on
refraction off
Hope this helps.
3:43am up 1 day, 2:12, 4 users, load average: 2.23, 2.22, 2.13
Dear Steve san:
I make test your scene file and get report from memory short error.
My application is MPW MrC version(based official mac 3.1g r2).
I set 128MB to application and system vertial memory is on,
(Power mac G3 DT233 memory 160MB VM set to 320MB).
Report is like this:
Creating bounding slabs.
Scene contains 5185 frame level objects; 0 infinite.
Creating vista buffer.
Creating light buffers...
Creating Photon Maps.
Building Photon Maps.........................................................
Slab building error.
Ran out of application memory; Increase POV-Ray application memory size.
Reclaiming memory
-- [Finish] File=photonsbug8.pov,Time=00.1.30 4:27:46 PM
POV-Ray Mac Memory Cache Statistics
Cache hits: 25467755 Cache misses: 816
Total calls to malloc: 25468571 Cache hit rate: 99%
Y.Tanabe
Kobe,Japan
> Scene below:
> Hope this helps.
On Sun, 30 Jan 2000 16:49:46 +0900, Y.Tanabe <tec### [at] kh rim or jp> wrote:
>Dear Steve san:
>Reclaiming memory
Thanks, I'll have to wait untill my machine has finished rendering it's current
scene before I try this again. The current render has been going for more than
30 hours, so I don't want the machine to crash just yet.
2:31pm up 1 day, 13:01, 4 users, load average: 2.29, 2.25, 2.10
Right I've now done some extensive experimentation.
I took a scene that will render in Official pov but requires
more memory than I have, so it's just a standard scene with
millions of objects. In both official and Mega it gives
me a message telling me that it's run out of memory, no problem.
But when I render a scene with photons and it runs out of memory
while creating the photon data the box freezes completely.
I had to go out (yes actually outside the house) today so I set
the render running with xmegapov -Imyscene.pov and left it for
a few hours, it froze, so I thought give it a few hours and it
might sort itself out, but after the screen had cutout I couldn't
even get my display back by pressing the shift key the way I
normally do. Before losing the screen and after the freeze
the mouse pointer wouldn't move, I couldn't Alt-Ctrl-Fn to another
session, I couldn't Alt-Ctrl-Backspace out of X.
One more thing that I will try is running a scene that has photons,
but runs out of memory before it gets to the point where it starts
to generate the photon data. I will try this soon, and post the
results in this thread.
6:37pm up 4:09, 2 users, load average: 1.44, 1.22, 1.14
On a scene that runns out of memory before starting to
generate the photon data the machine doesn't freeze.
8:53pm up 6:26, 2 users, load average: 1.60, 1.52, 2.03
Steve wrote in message ...
Sounds like a recursive call to Error(). Someone who has a debugger might
want to check this out.
Mark
