POV-Ray : Newsgroups : povray.unofficial.patches : [Q] about spwan failure???? Server Time
16 Jun 2026 15:49:03 EDT (-0400)
  [Q] about spwan failure???? (Message 1 to 2 of 2)
Subject: [Q] about spwan failure????
Date: 18 Dec 1999 01:34:11
Message: <385b2ae3@news.povray.org>
Dear all,
I have a machine with only master node.
When I excuted a command 'pvmpov +iskyvase.pov +h480 +w640 +FT +v1 -x -d
+a0.300 -q9 -mv2.0 -b1000 -nw32 -nh32 -nt1 -L/home/node/povray31/include',I
occured  a provblem.
That is:
$pvmpov +iskyvase.pov +h480 +w640 +FT +v1 -x -d
Spawning pvmpov with 1 PVM tasks on 1 hosts...
...spawn failure because excutable not found
...No tasks spawned! Quitting.
KeunHo Yoon.
Subject: Re: [Q] about spwan failure????
Date: 18 Dec 1999 08:05:00
Message: <385B8678.78337BEF@mailbag.com>
KeunHo Yoon wrote:
> Dear all,
> occured  a provblem.
> That is:
1) Did the build succeed?
2) Is the executable where you think it is? PVM looks by default in
~/pvm3/bin/$PVMARCH, then in $PVM_ROOT/BIN/$PVMARCH.
3) What directory are you starting in? (affects the first default path)
4) Do you have $PVM_ROOT set? (affects the second default path)
Looks like you have a user called node with a home directory of
/home/node.  Is PVM installed under /home/node/pvm3/bin/$PVMARCH? If
not, does node have $PVM_ROOT set?  If PVM is installed in some other
user's home directory, and node doesn't have that environment variable
set, that would explain it.
-Mark Gordon
