POV-Ray : Newsgroups : povray.unofficial.patches : ini_option "Width=..." Server Time
12 Jul 2026 18:06:43 EDT (-0400)
  ini_option "Width=..." (Message 1 to 3 of 3)
Subject: ini_option "Width=..."
Date: 14 Dec 1999 20:26:43
Message: <3856EE46.C45A3B84@gci.net>
Just an observation for WinMegaPOV .2
When I set the width and height of the
picture with the ini_option, the display
window is set to the size that I ask for but
the rendered image is the size set in the ini
file. Example: when I set
global_settings {ini_option "Width=800" ini_option "Height=600"}
in the scene file and use 160x120 in the ini file,
I get a large(800x600) display window that has a
160x120 sized portion of the total image in it.
Now, if I set +W800 +w600 on the command line
and select 160x120 from the ini file, I get the
800X600 sized image in full. As I would expect.
Have fun chasing this one down.
Mr. Art
Subject: Re: ini_option "Width=..."
Date: 14 Dec 1999 22:56:53
Message: <38571185@news.povray.org>
Neat feature.  Oh, oops, not.
Actually someone just might try and come up with a use for that mis-feature.
In fact, if it could be positioned as well... nah...
"mr.art" <mr.### [at] gcinet> wrote in message news:3856EE46.C45A3B84@gci.net...
> Mr. Art
Date: 14 Dec 1999 23:24:48
Message: <38571810@news.povray.org>
Here's the problem:
At some point POV checks to see if you entered The End_Column and End_Row
ini options by checking if they are still set to -1 (which is how they
start).  If you did not, then it sets them to the size of the image.
Unfortunately, this is done for the first time after reading the command
line and INI files and before parsing (and reading ini_option).  After that
point, POV assumes that you purposely set End_Column and End_Row (which is
an incorrect assumption in this case).
A workaround is to explicitly set the Last_Column and Last_Line options
using ini_option.  Example:
global_settings{
  ini_option "Width=512"
  ini_option "Height=384"
  ini_option "End_Column=512"
  ini_option "End_Row=384"
This will be fixed in the next release.
-Nathan
mr.art <mr.### [at] gcinet> wrote...
> Mr. Art
