Hello,
This simple scene render correctly, without any warning message or
error, with official povray and UVpov6.2 but with MegaPov0.2
(for windows) I have this error:
> Copyright 1999 POV-Ray Team(tm)
> This is an UNSUPPORTED UNOFFICIAL COMPILE by Nathan Kopp (email: Nat### [at] Koppcom).
> Parsing Options
> Input file: C:\AAAAPhys\Untitled.pov (compatible to version 3.14159)
> Remove bounds........On Split unions........Off
> Library paths: C:\Utilitaires\POVRay\INCLUDE
> Output Options
> Image resolution 640 by 480 (rows 1 to 480, columns 1 to 640).
> Output file: Untitled.bmp, 24 bpp (system format)
> Graphic display......On (type: 0, palette: 3, gamma: 2.2)
> Mosaic preview......Off
> Continued trace.....Off Allow interruption..Off Pause when done.....Off
> Verbose messages.....On
> Tracing Options
> Quality: 9
> Bounding boxes.......On Bounding threshold: 3
> Light Buffer.........On Vista Buffer.........On Draw Vista Buffer...Off
> Antialiasing.........On (Method 1, Threshold 0.300, Depth 3, Jitter 1.00)
> Radiosity...........Off
> Animation Options
> Clock value.... 0.000 (Animation off)
> Redirecting Options
> All Streams to console..........On
> Debug Stream to console.........On
> Fatal Stream to console.........On
> Render Stream to console........On
> Statistics Stream to console....On
> Warning Stream to console.......On
> #declare pig=yes;
> #if (pig)
> pigment { bozo color_map{
> // s is delta for the contour lines
> #declare s <----ERROR
> C:\AAAAPhys\Untitled.pov:9: error: undeclared identifier expected but s found
instead.
> Returned from renderer (non-zero return value)
Here is the code:
plane{
z,0
texture
#declare pig=yes;
#if (pig)
#declare s=.05;
#declare a=0;
#while(a<=1)
[a rgb 1]
[a+s/4 rgb 1]
[a+s/4 rgb .5]
[a+s/4*2 rgb .5]
[a+s/4*2 rgb 1]
#declare a=a+s;
scale 1}
finish { specular 1 }
#else
pigment { color rgb 1 }
normal { bozo 0.5*5
slope_map{[0 <0,0>][1 <1,0>]}
scale 1 }
light_source { <500,0,-100> color rgb 1 }
// light_source { <0,500,-100> color rgb 1 }
camera
location <0.0 , 0.0 ,-2.25>*2
up y
right x
look_at <0.0 , 0.0 , 0.0>
orthographic
If a replace s by ss all is ok!
Fabian.
Fabian Brau wrote:
>Hello,
"s" is a new keyword for the isosurface objects (8.4.2.12 in multipat.htm).
It seems to say nowhere what the use of "s" is.
Ingo
Pov-Ray : http://members.home.nl/seed7/
// <r, s, t> -- coordinates in isoblob space
Ingo
Fabian Brau <fab### [at] umhacbe> wrote:
> Hello,
> This simple scene render correctly, without any warning message or error,
> with official povray and UVpov6.2 but with MegaPov0.2 (for windows) I have
> this error:
>> > pigment { bozo color_map{ > // s is delta for the contour
>lines
> #declare s <----ERROR > >
>found instead. >
>! If a replace s by ss all is ok!
> Fabian.
OK, I know your problem has been solved.
This kind of problem is sure to become a FAQ (maybe it should be added
to that group?). So it is time to ask all POV-users to keep in mind what
follows and spread the word.
Reserved keywords for POV will always use only small letters!
Please make it a habit of using at least one Capital letter in declared
identifiers or variables. This way you will never run into conflict with
the currently reserved keywords or the ones that might be added in the
future.
I have seen too many macros using variables without a capital
letter in the identifier causing problems with keywords of new patches.
So, please, when you are writing scenes or macros, keep this in mind.
Smellenbergh
-- e-mail:sme### [at] skynetbe
http://users.skynet.be/smellenbergh
That's what I was going to say, only I don't have as much information on the
subject. I had this problem before, and fixed it by simply capitalizing my
#declared word.
> > Hello,
> > this error:
> >lines
> >found instead. >
> > Fabian.
> future.
> Smellenbergh
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial: http://members.aol.com/stbenge
Thank you!!
I didn't know this about small letter for keyword!
But I just want to add that this code was made by Nathan
to show bozo problem ;).
Fabian
> > Hello,
> > this error:
> >lines
> >found instead. >
> > Fabian.
> future.
> Smellenbergh
