TonyB wrote:
> Did you check out the link? It's pretty cool. Gamasutra is a great site,
> even for non-game programmers. In the article about bicubic bézier surfaces,
> they manage to reduce the computations from 3978 adds and 8586 multiplies to
> 1506 adds and 1488 multiplies. I have no idea how useful this would be to
> POV-Ray, however. I also found out where the Nintendo developers go to. =)
I discovered it several months ago. It truly is a valuable resource on
several topics in graphics programming.
-Mark Gordon
Subject: Re: Mipmapping and trilinear filtering in povray
Date: 11 Nov 1999 04:41:39
Message: <382a8f53@news.povray.org>
Thorsten Froehlich <tho### [at] trf de> wrote:
: Hmm, for now a workaround migth be to use an external program to scale down
: the image and use that as image map. Not a great workaround I have to admit,
: but it will work (if Nieminen needs a workaround right now).
But then the image map will not be detailed near the camera.
And no, it's not a problem I'm currently having. It's just an idea.
On 9 Nov 1999 07:43:37 -0500, Nieminen Juha
<war### [at] punarastas cs tut fi> wrote:
> Now, povray only supports bilinear filtering. How about adding automatic
>mipmapping and trilinear filtering to it?
What about implementing bicubic interpolation, similiar to Photoshop?
That program seems to resize images very well.
On Tue, 23 Nov 1999 10:20:59 -0500, Glen Berry <7no### [at] ezwv com>
Bicubic interpolation is supported by POV. Check out "bitmap
modifiers" in the docs.
Peter Popov
ICQ: 15002700
[On 9 Nov 1999 07:43:37 -0500, Nieminen Juha <war### [at] punarastas cs tut fi>]
| However, when the texels are smaller than the screen pixels, the bilinear
| interpolation doesn't help much.
True, that's why we have antialiasing.
| like broken lines, moire patterns, etc (even when antialiasing in on)
Not if used correctly. You should try the adaptive supersampling.
| In most 3D engines (renderers, 3D games, 3D video cards...) this problem
| is corrected by calculating mipmapping and trilinear filtering.
True. But the reason they do this is because it's more convenient than
proper antialiasing like the one we have in POV-Ray, and it's easy to
implement in hardware. Also, trilinear filtering bring on other visual
artifacts. For instance, resolution drops in both directions when a
texture is viewed at an angle. Hardware tries to cope with this by
introducing so called anisotropic filtering, but that also has it's
limits.
In POV-Ray, supersampling can be used to correct any aliasingproblems
you may have, and it will work on any texture, not just image maps.
| The result is very good.
It pales in comparison with proper supersampling.
A penny for your thoughts.
Mine are more expensive.
Date: 24 Nov 1999 08:07:20
Message: <383be308@news.povray.org>
Not really. Textures should antialias themselves based on the "size" of
the ray hitting them, as well, if you want to avoid certain kinds of aliasing.
These are my opinions. I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
