POV-Ray : Newsgroups : povray.unofficial.patches : Updated patch source available Server Time
2 Nov 2024 13:20:19 EDT (-0400)
  Updated patch source available (Message 1 to 8 of 8)
Subject: Updated patch source available
Date: 8 Nov 1999 13:15:50
Message: <382713F9.A68A6045@compuserve.com>
I have uploaded the latest version of my patch source code:
chrishuff.dhs.org/pov/morepatterns.zip
This patch includes the blob pattern and pigment, the proximity pattern,
the object pattern, and the z-buffer patch. I may go ahead and merge it
with my other patch work, if the new version of the Superpatch isn't
released soon.(Ron? How is it going? :-) )
It includes draft docmentation, but no example scenes(yet).
I haven't updated the web site itself yet, but I will soon. I may also
add some more example images.
If anyone has trouble using this .zip file, please tell me. I have had
problems before, I suspect the program I am using may not work
correctly.
Subject: Re: Updated patch source available
Date: 9 Nov 1999 07:35:03
Message: <3828158C.10219C7C@compuserve.com>
I forgot about another feature I added. :-)
I have added text object alignment to the text object. To use it, place
one of these keywords after the text string:
align_left FLOAT_PAGE_WIDTH
align_center FLOAT_PAGE_WIDTH
align_right FLOAT_PAGE_WIDTH
FLOAT_PAGE_WIDTH is the width of the "page" that the text object is
aligned to. The page is actually just a boundary along the x-axis to
align the text object against. The patch does not protect against having
the text object run off the edge of the page.
With align_center, FLOAT_PAGE_WIDTH is optional and does nothing.
With align_left, the left edge of the text object is aligned with the
left edge of the page.
With align_right, the right edge of the text object is aligned with the
In a future release, I will make FLOAT_PAGE_WIDTH optional for all
three, if it is not present, the width of the text object will be used
for the page width. I may someday add line wrapping, but I will have to
study the source more closely.
BTW, do you think it would be useful to have an "auto_center" keyword
which centers the object over the origin? It would take an optional
vector parameter, so auto_center y would center it along the y-axis, and
so on. This would make it easier to understand the code later than
declaring the object and using min_extent and max_extent, but it is
quite easy to do with those keywords, and might be better done as a
macro than a patch.
Subject: proximity pattern WARNING
Date: 9 Nov 1999 07:39:14
Message: <38281687.812AE9D3@compuserve.com>
Do not use the proximity pattern with height fields, it gave me a lot of
dda_traversal() warnings and crashed when I tested it. I will be looking
at this more closely. Any suggestions?
Date: 11 Nov 1999 08:19:56
Message: <382AC27A.6C600B55@ti-nov3.fbe.fh-weingarten.de>
I have trouble with your zip-file.
I've test to extract it with Winzip & Powerzip....
Same Problems!!!
I didn't get plain textfiles..... :-((((
Maybe I will integrate your Patch in my private custom compile and test it!
(It based at Superpatch, latest?!)
v
Zan
> correctly.
Date: 11 Nov 1999 08:42:26
Message: <382AC869.485D066@compuserve.com>
Hrm, other people have reported this problem with .zip files from me, I
suspect that it is the compression program which I am using.
Is anyone else having problems?
Can anyone recommend a good program to create .zip files on the
Macintosh?
Another possibility is the return characters: the Mac uses different
line return characters than Windows, which will make the code unreadable
without going through and adding in all of the returns by hand.
I will upload a .zip with the text files converted to PC-text format
before being placed in the archive, maybe you will be able to read that.
Date: 11 Nov 1999 08:47:58
Message: <382AC8F6.FD17E917@pacbell.net>
> Same Problems!!!
Same here. It is those pesky Macintosh line feeds that is causing it.
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 11 Nov 1999 09:17:07
Message: <382AD089.6C967B4C@compuserve.com>
I have uploaded a PC-text format version:
http://chrishuff.dhs.org/pov/morepattpc.zip
It isn't linked to from the main site yet, if it solves the problem I
will add a link.
Date: 11 Nov 1999 10:22:50
Message: <382adf4a@news.povray.org>
In article <382AC8F6.FD17E917@pacbell.net> , Ken <tyl### [at] pacbellnet>
Just use the POV-Win editor to convert the files.  Also, when compiling them
you usually use a development env. that supports it, VC 5 and 6 as well as
Borland have no problems with the line endings, it is just the stupid
notepad that does have this problems ;-)
    Thorsten
e-mail: tho### [at] trfde
