POV-Ray : Newsgroups : povray.unofficial.patches : save_file, load_file "mediaph.ph" Server Time
20 Nov 2025 01:40:17 EST (-0500)
  save_file, load_file "mediaph.ph" (Message 1 to 8 of 8)
Subject: save_file, load_file "mediaph.ph"
Date: 6 Nov 1999 15:06:15
Message: <38248a37@news.povray.org>
Is this somewhere in your docs? Is it only useful for photons? I ask this
because you might want to change the keyword from "*_file" to "*_photons",
seeing as this might cause confusion later on.
This is pretty cool. I assume that it stores the photon map for situations
when there is no movement of the lightsource(s) itself(themselves), right?
Could a similar thing be done with radiosity, to avoid recalculation? I
remember that at a demonstration I went to, Lightscape would (AFAIK) only
precalculate the radiosity directly into the textures, and then you could
render normally with everything looking radiant.
Subject: Re: save_file, load_file "mediaph.ph"
Date: 7 Nov 1999 16:15:02
Message: <3825ebd6@news.povray.org>
I might rename to *_photons.  However, if we keep it as save_file and
load_file, then we could use the same keywords in the radiosity{} block (no
need for new keywords) to save/load radiosity.  And yes, this could
definately be done with radiosity (the radiosity octree can already be
saved/loaded by POV for continued renders).  The only problem with radiosity
is that POV will usually calculate more radiosity data during the ray-trace
pass.  This could be prevented if necessary, though.
This feature (saving/loading the photon map) is also intended to help with
network rendering possibities in the future.  It should be in the docs
somewhere.  If not, I'll have to add it.
-Nathan
TonyB <ben### [at] panamaphoenixnet> wrote...
Date: 7 Nov 1999 22:15:54
Message: <3826406a@news.povray.org>
Good foresight... it actually crossed my mind (very briefly, so I ignored
it...)
>And yes, this could
Aha... so why isn't that being done already? <Yoda>Hmmmm?</Yoda>
Please, be my guest... prevent it... :)
I haven't read the docs extensively, but I don't think I saw that. The
network rendering would sure be swell.
Date: 8 Nov 1999 05:27:09
Message: <3826a57d@news.povray.org>
Are there any other advantages of saving the photon map than speeding up
a continued trace?
  The scene usually changes from render to render (trial and error style
modelling) so I think that the photon map changes as well.
Date: 8 Nov 1999 05:32:50
Message: <3826A687.1E1F4E1A@pacbell.net>
> a continued trace?
Personaly I do not even turn on photons until my scene is fully developed.
Then I spend time tweaking the photon and lighting settings to optimize
their effect for the scene I am working on. In either case a saved map
would serve no purpose because the parameters for the photons would change
between each render session.
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 8 Nov 1999 05:43:45
Message: <3826a961@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: Personaly I do not even turn on photons until my scene is fully developed.
: Then I spend time tweaking the photon and lighting settings to optimize
: their effect for the scene I am working on. In either case a saved map
: would serve no purpose because the parameters for the photons would change
: between each render session.
  That was what I meant.
Date: 8 Nov 1999 08:58:39
Message: <3826d70f@news.povray.org>
If you have an animation where the objects affecting the photons do not
change, this could save a lot of time.  One of the demo scenes for UVPov6.1
has the following code:
    #if(clock=0)
    save_file "mediaph.ph"
    #else
This is especially the case if the camera is the only thing that moves.
Now, as this relates to radiosity -- Unlike photons, the computation of
radiosity is very camera-dependant.  If generate the radiosity data and then
move the camera and re-use it, you will likely be missing some spots.
-Nathan
Nieminen Juha <war### [at] punarastascstutfi> wrote...
> a continued trace?
Date: 8 Nov 1999 09:25:53
Message: <3826dd71@news.povray.org>
I see three benefits:
a) Continued trace
b) Network rendering
c) Specific animations
In cases b and c, the same benefit repeats itself. Why recalculate the map,
when it won't change, no matter where you move the camera to? The idea in b
is that all computers will be working on the same frame. The idea in c is
that your lights and objects don't move. As long as this is true, why waste
time? Say you want to do a walkthrough down a hall with the lights pouring
through the windows and the media with the photons and everything. They
won't change, just the camera position. See what I mean?
