Well, I've uploaded UVPov 6.1. Lots of bug fixes. Plus photons in media.
Have fun. And continue with the polite and informative bug reports
(including demo scenes). They do help a lot.
-Nathan
Goooo, Naaaathan!!! Hoo! Hoo! Hoo!... =)
Dammit, and I had some important work to do...
Oh well, it will have to wait. Gotta see them photons in media!
Margus
> -Nathan
No fractal patch included?
I think that would require a bigger version change, like 7.0.
I wanted to clobber those bugs, first (before potentially introducing more).
And I had already started on media photons. Adding the fractal patch will
probably be in versio 6.2 (version 7.0 should hopefully include a bunch of
superpatch features... provided days start lasting 26 hours).
-Nathan
TonyB <ben### [at] panamaphoenixnet> wrote...
Hello Nathan!
You are very fast to correct bug!!! Personally, I appreciate very much
Fabian.
> -Nathan
Btw, I still can't find any reference to the ini_option command in the
documentation.
Writing documentation is so much less fun than writing code. Anyway, I'll
document it soon (it's on my to-do list).
-Nathan
Nieminen Juha <war### [at] punarastascstutfi> wrote...
> documentation.
Nathan Kopp <Nat### [at] koppcom> wrote:
: Writing documentation is so much less fun than writing code. Anyway, I'll
: document it soon (it's on my to-do list).
Thanx :)
Btw, I compiled the newest version of uvpov in this Solaris Sparcstation.
Your //-comments caused lots of trouble. There's no easy way to automatically
replace them with /* ... */. One problem is that some of the //-comments
are inside a bigger /**/-comment block, so replacing the //-comments breaks
the bigger block.
One possibility is just to automatically remove the //-comments, but that
might cause some problems too...
You have some very tricky comment lines like the line 1028 in cones.c:
It's not trivial for a line-by-line filter to see whether that is the
beginning of an //-comment or the end of an /*...*/ comment.
Also the http:// lines cause headache to the filtering.
Would it be too much asked if you could fix this?
The result was that I got most of the comments working by filtering, but
had to make some modifications by hand before it was completely fixed.
The lack of ending newline at the end of radiosit.c also caused problems
with the filtering (I still don't know why).
