POV-Ray : Newsgroups : povray.unofficial.patches : Memory Leakage in Superpatch 3.1e Server Time
18 May 2026 02:38:16 EDT (-0400)
  Memory Leakage in Superpatch 3.1e (Message 1 to 1 of 1)
Subject: Memory Leakage in Superpatch 3.1e
Date: 5 Nov 1999 00:20:21
Message: <38226915@news.povray.org>
After rendering a 100 frame animation on my custom compile of the
Superpatch, I checked its report on memory leakage to see where the 16MB of
memory leakage came from.  I found the following entries:
File:C:\Temp\workarea\SOURCE\Matrices.c  Line: 986  Size:256
   I think that this leakage occurs because the UV transform is not freed
when an object is deallocated.  I haven't been able to find any references
to freeing UV transforms in the source code.
File:C:\Temp\workarea\SOURCE\Splines.c  Line:  80  Size:12288
File:C:\Temp\workarea\SOURCE\Splines.c  Line:  78  Size:8
   I haven't had a chance to try tracking this one down.
File:C:\Temp\workarea\SOURCE\Normal.c  Line: 563  Size:132
File:C:\Temp\workarea\SOURCE\Texture.c  Line: 871  Size:116
   I think these may be from my modifications to the superpatch that reduce
the memory used when you only specify part of a texture while texturing an
object, but I'm not sure yet.
File:C:\Temp\workarea\SOURCE\windows\pvbmp.c  Line: 744  Size:1536
   This one is in the official source as well.  The fix is to add the lines
if(magic != NULL)
    POV_FREE(magic);
to the end of "Open_BMP_File" just before the line "return 1;" (about line
771).
Mark
