POV-Ray : Newsgroups : povray.unofficial.patches : Bug in UV-Pov alpha 5 Server Time
20 Nov 2025 01:38:48 EST (-0500)
  Bug in UV-Pov alpha 5 (Message 1 to 3 of 3)
Subject: Bug in UV-Pov alpha 5
Date: 2 Nov 1999 11:42:08
Message: <381f1460@news.povray.org>
I found this bug in UV-Pov alpha 5. I have not tested it in alpha 6 but
it may probably appear there too.
  It looks a lot like a normal flipping problem similar to the old
average normal bug. It seems exclusive to photon mapping since the bug
doesn't appear when photon mapping is turned off.
  In the following scene there are two cylinders casting shadows over two
gaps in the wall. The left one is a real gap made by differencing a box
from the wall. The right one is a "fake" gap made with a normal pattern.
The dim caustic light in the left one is ok, while in the right one the
gap is dark.
  This caused a problem in my "landmarks" irtc entry, but I didn't study
that carefully until now.
  If you don't have my photons.inc, here it is:
#ifndef(UsePhotons) #declare UsePhotons=yes; #end
#ifndef(phd) #declare phd=1; #end
global_settings
  #if(UsePhotons)
    photons
    { gather 20,100
      radius 0.1*phd, 2, 0.1*phd
      autostop 0
      jitter .4
      expand_thresholds 0.2, 40
      #ifdef(PhotonsMaxTraceLevel) max_trace_level PhotonsMaxTraceLevel #end
      #ifdef(PhotonsADCBailout) adc_bailout PhotonsADCBailout #end
#macro Photons(Refl,Refr,Ignore)
  #if(UsePhotons)
    photons
    { separation .01*phd
      reflection Refl
      refraction Refr
      #if(Ignore) ignore_photons #end
  And here is the scene showing the bug:
#declare phd=2;
#include "photons.inc"
camera { location <0,10,-15> look_at 0 angle 35 }
light_source { <120,2,-100> 1 }
difference
{ plane { y,0 }
  box { <-.5,-.5,-10><.5,.5,10> rotate z*45 scale <1,.1,1> translate -x*2 }
  pigment { rgb 1 }
  normal
  { gradient x .5 slope_map
    { [0 <1,-1>][.1 <0,-1>][.1 <0,1>][.2 <1,1>][.2 <1,0>][1 <1,0>]
    scale 7 translate x*10
  rotate x*-90
#declare Obj=
  difference
  { cylinder { .001,y*2,.5 scale 2 }
    cylinder { 0,y*2.01,.45 scale 2 }
    pigment { rgbf <.5,1,.5,.98> }
    interior { ior 1.5 }
    Photons(no,yes,yes)
object { Obj translate <4+.2,-1,-1.5-.2> }
object { Obj translate <0+.2,-1,-1.5-.2> }
Subject: Re: Bug in UV-Pov alpha 5
Date: 3 Nov 1999 10:11:22
Message: <3820509a@news.povray.org>
Nathan, did you manage to replicate the bug?
Date: 3 Nov 1999 23:55:07
Message: <382111ab@news.povray.org>
I was able to replicate the bug and I have found a fix.  I'm waiting for bug
reports to die down to release the next version of UVPov.
-Nathan
Nieminen Juha <war### [at] punarastascstutfi> wrote...
[clip]
