POV-Ray : Newsgroups : povray.unofficial.patches : Patch Documentation Server Time
12 Jun 2026 03:32:27 EDT (-0400)
  Patch Documentation (Message 13 to 22 of 22)
Subject: Re: Patch Documentation
Date: 21 Sep 1999 23:32:20
Message: <37e84dc4@news.povray.org>
By the way, if you really want to have all sorts of info about the photon
mapping in UVPov, download the PostScript file linked from
http://nathan.kopp.com/photons.htm.  That PS file is the paper that I wrote
for my directed study, and it probably contains more info than you want or
need.  It lacks tips and tricks, because I did not know of many tips or
tricks when I wrote the paper.
-Nathan
Date: 22 Sep 1999 23:42:38
Message: <eaDpN5TwtLykRJf7Yw4VIefHqZ+9@4ax.com>
On Tue, 21 Sep 1999 23:32:53 -0400, "Nathan Kopp" <Nat### [at] Koppcom> wrote:
  Nathan, by any chance would you happen to have this document in another
form such as plain text or Adobe Acrobat or HTML? I don't have anything to
read a Postscript file with. However, don't go through the hassle of
converting it or anything like that - I'm just curious.
Alan ---------------------------------------------------------------
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
Date: 23 Sep 1999 00:27:39
Message: <37E9AB94.E4DF0412@pacbell.net>
Ditto.
Ken Tyler
See my 1000+ Povray and 3D Rendering and Raytracing Links at:
Date: 23 Sep 1999 04:08:37
Message: <qqmiu52rqwr.fsf@goldach.fmi.uni-konstanz.de>
Alan Kong <ako### [at] pacbellNO-SPAMnet> writes:
You should really get a version of "ghostscript" and "ghostview". The
former is a free Postscript-Interpreter, the latter a viewer that uses
it. They are available for a lot of OSes (e.g. Windows, OS/2, Linux,
Solaris,...). Furthermore, ghostscript can be used to print the documents
on a variety of printers.
Both programs should be available on your favorite ftp server.
http://www.fmi.uni-konstanz.de/~willhalm
Date: 23 Sep 1999 04:14:23
Message: <37E9E0D1.5C6CF20F@pacbell.net>
> Thomas
http://www.cs.wisc.edu/~ghost/
Ken Tyler
Date: 23 Sep 1999 19:48:13
Message: <37eabc3d@news.povray.org>
I chose PS format for cost & portability.  While Acrobat viewer is free, the
creator is not.  The paper was written in Wordperfect, and the "save as
HTML" feature is far from perfect.  And, as mentioned, PS viewers are
available, and PS creators are as easy to come by as your favorite PS
printer driver.  If enought people request HTML, I'll put together an HTML
version, though.
-Nathan
Date: 23 Sep 1999 23:06:24
Message: <slrn7ul9d2.1qd.parkerr@linux.parkerr.fwi.com>
>creator is not.
GhostScript for Unix comes with a free ps2pdf utility.  It's not perfect, but
if you used normal PostScript fonts it'll work pretty well.
Date: 25 Sep 1999 02:30:28
Message: <e2vsNxZTpeuBMfew2g89dyGItMma@4ax.com>
On 23 Sep 1999 10:08:36 +0200, Thomas Willhalm
  I will try this, thanks.
Alan
Message: <omvsN6=Z9u2WD+4TFOJ9JUcniqmT@4ax.com>
  I'll check this out, Ken. Thanks.
Alan
Date: 25 Sep 1999 02:30:29
Message: <xmvsNxdIz67taugyf=3oWz75dsK4@4ax.com>
On Thu, 23 Sep 1999 19:48:42 -0400, "Nathan Kopp" <Nat### [at] Koppcom> wrote:
>And, as mentioned, PS viewers are available...
  I will get a PS viewer and try it out. Thanks.
Alan
