POV-Ray : Newsgroups : povray.unofficial.patches : Bug in UVPov 5.4 Server Time
23 Mar 2026 20:29:14 EDT (-0400)
  Bug in UVPov 5.4 (Message 1 to 10 of 14)
Subject: Bug in UVPov 5.4
Date: 17 Jul 1999 01:27:29
Message: <37901441@news.povray.org>
This appears to be my night for finding bugs in POV-Ray.  First, I found an
apparent bug in the CodeMax editor (see povray.windows), then I found the
triangle mesh bug in the Superpatch, and now this:
In UVPov 5.4, it appears that the parser expects a white space of some sort
at the end of every file.  If it does not find this, it gives the error
message "Unexpected end of file found."
Mark
Subject: Re: Bug in UVPov 5.4
Date: 17 Jul 1999 01:42:29
Message: <37901769.F61BAA34@pacbell.net>
> Mark
This was an official version bug that has been corrected by the Pov team. I
imagine once Chris releases the windows source code for v3.1g this fix will
make it into our popular pov patches as well.
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 17 Jul 1999 01:46:13
Message: <37901843.3EF08017@pacbell.net>
> > Mark
Here are the changes between public POV-Ray 3.1 and 3.1c
3.1c               1/29/99 Chris Young
Fixed radiosity preview with odd screen size.
Reinitialized max_trace_level & radiosity_trace_level properly
--->>>> Fixed token at end of file with no cr/lf or newline
Ken Tyler
Date: 17 Jul 1999 18:01:21
Message: <3790FDD8.D8F947B6@Kopp.com>
The reason for this is that UVPov was started from the POV-Ray 3.1a code
base, and it was not fixed until 3.1c (as Ken pointed out).  I've kept on
top of most of the bug fixes, but I have missed some of them.  If anyone
knows what I have to change to fix this, let me know and I will.
-Nathan
> Mark
Date: 19 Jul 1999 05:46:51
Message: <3792f40b@news.povray.org>
Nathan Kopp <Nat### [at] koppcom> wrote:
: The reason for this is that UVPov was started from the POV-Ray 3.1a code
: base, and it was not fixed until 3.1c (as Ken pointed out).  I've kept on
: top of most of the bug fixes, but I have missed some of them.  If anyone
: knows what I have to change to fix this, let me know and I will.
  Why don't you just use the latest povray source instead of duplicating
the bug fixes to your old 3.1a version? I can imagine it's a lot of
wasted time.
Date: 19 Jul 1999 08:34:58
Message: <37931B4F.80D9CFFB@aol.com>
DOS, MacIntosh, Linux and Unix are 3.1g but Windows platform
(UVpov-based pvengine) is still 3.1a at www.povray.org last I saw.
> wasted time.
Date: 19 Jul 1999 09:22:50
Message: <379326aa@news.povray.org>
The fix is in the Echo_getc() function in tokenize.c.  You can find the
fixed code in the official 3.1e/3.1g source or in the superpatch.
Date: 19 Jul 1999 23:38:28
Message: <3793EFD1.D8E855AB@Kopp.com>
> wasted time.
Actually, it _saves_ time.  The photon mapping patch consists of many
small changes to a variety of files in POV-Ray (mostly scattered around
in lighting.c). Taking a fresh source and making all those changes is
quite a time-consuming task (I've spent hours incorporating it into
the superpatch).  Plus, I want to know exactly how various bugs have been
fixed, so I like to apply the fixes myself.  And on top of that, I have
made a plethora of other changes to POV that I would also have to
incorporate into the new source every time I want to update to a new
code base.
-Nathan
P.S.  I am not experienced with the diff tools, so I do updates by hand.
Maybe someday I'll get around to learning how to use diff.
Date: 20 Jul 1999 02:37:38
Message: <37941932@news.povray.org>
: The photon mapping patch consists of many
: small changes to a variety of files in POV-Ray (mostly scattered around
: in lighting.c). Taking a fresh source and making all those changes is
: quite a time-consuming task
  This is one reason why modularity is a very good thing in programming...
  Perhaps povray4 will be more modular and more easy to change.
Date: 20 Jul 1999 09:02:24
Message: <37947360@news.povray.org>
You really should.  The superpatch would never have happened without
the help of diff, diff3, and some cobbled-together perl scripts.  I
was even able to treat the 3.0 -> 3.1 transition in the official code
as just another (huge) patch.
