POV-Ray : Newsgroups : povray.unofficial.patches : Superpatch built-in functions Server Time
18 Apr 2026 16:06:47 EDT (-0400)
  Superpatch built-in functions (Message 1 to 9 of 9)
Subject: Superpatch built-in functions
Date: 15 Jul 1999 16:12:30
Message: <378e3c6d.6326610@news.povray.org>
I have been trying out SP and cannot get it to recognise any of the built-in
function names - Sphere, rounded_box, Torus, Superellipsoid, helix1, helix2.
Have I got the syntax wrong?
eg.
isosurface {  function { Sphere 1 }  pigment { Red}}
This seems to be correct according to the docs, but SP is looking for a float
factor after function and says Sphere is an undeclared identifier.
I have tried many other syntactical combinations without success.
David
dav### [at] cwcomnet
http://www.hamiltonite.mcmail.com
Subject: Re: Superpatch built-in functions
Date: 15 Jul 1999 16:21:25
Message: <378e42c5@news.povray.org>
>eg.
The quotes in the docs are significant:
isosurface {  function { "Sphere" 1 }  pigment { Red}}
Date: 15 Jul 1999 18:35:26
Message: <37905d30.14714648@news.povray.org>
Thanks for the prompt response Ron, but this doesn't work either, the diagnostic
is "missing right brace in function".
I tried;
isosurface {  function  { "Sphere, 1" }  pigment { Red}}
which gave the diagnostic "cannot load function"
Incidently I can't find any reference to quotes in the docs.
David
Date: 16 Jul 1999 09:05:49
Message: <378f2e2d@news.povray.org>
>I tried;
Hm, you're right.  They must have somehow gotten lost in the
translation.  Here's the syntax that works for me:
isosurface {  function { "Sphere" <1> }  pigment { color red 1}}
Date: 16 Jul 1999 14:34:51
Message: <379057ef.580831@news.povray.org>
>>I tried;
Thanks Ron, thats it!  It's the angle brackets wot done it.  I've got too used
to the easy going syntax of POV-Ray :-)
David
Date: 19 Jul 1999 05:42:22
Message: <3792f2fe@news.povray.org>
David Wilkinson <dav### [at] cwcomnet> wrote:
:>isosurface {  function { "Sphere" <1> }  pigment { color red 1}}
: Thanks Ron, thats it!  It's the angle brackets wot done it.  I've got too used
: to the easy going syntax of POV-Ray :-)
  Why there have to be angle brackets? It breaks the ideology of povray that
you can specify a vector with just a float value.
Date: 19 Jul 1999 07:14:43
Message: <3793089B.F8DC100@atos-group.com>
Which ideology ?
It rather breaks the lazyness...
A vector should within bracket... always.
Of course, you're allowed things like "3*x" but then x is a shortcut for
<1,0,0>.
the only examples I'm not satisfied with the <vector> approach
is for "scale" and "rotate" where it is rather an array of float than a
true vector.
but they were there before the array, so that's an historical reason.
(and scale <0,0,0> is not so terrible, whereas rotate sometime gives me
headache).
Now, I do not understand a nut out of isosurface/function syntax.
Date: 19 Jul 1999 08:39:16
Message: <37931C51.4C0E036C@aol.com>
"scale <0,0,0>" eh? Okay, I know you meant that as a example vector for
this discussion but still... :)
'rotate <0,0,0>' would not be the headache-causing item in that case.
> <1,0,0>.
> true vector.
> headache).
Date: 19 Jul 1999 09:35:37
Message: <379329a9@news.povray.org>
Not my syntax, so I'm not 100% sure of why, but I suspect it's because that
argument isn't the same kind of vector we're used to.  For one thing, it's
a vector of functions, not of floats.  For another, I don't think it's
limited to five or fewer components.  So it doesn't get parsed by the
same code that parses normal vector arguments.  I expect one could still
make the angle-brackets optional, but that apparently just wasn't done.
