POV-Ray : Newsgroups : povray.unofficial.patches : REQ: 'parse' function Server Time
18 Apr 2026 16:06:48 EDT (-0400)
  REQ: 'parse' function (Message 1 to 10 of 10)
Subject: REQ: 'parse' function
Date: 12 Jul 1999 13:58:46
Message: <378b1e14.33579230@204.213.191.228>
Greetings all.
I just stumbled upon some limitations in the POV language and thought
of a way they could be avoided. These limitations are:
-you can't pass a macro as a parameter of another macro
-POV can't evaluate an expression to a float when reading from a file
The solution I have in mind is a parse(string) function. It simply
inserts the string in the code at the time of parsing (as include
files and macros are treated). So you can to something like:
#macro lissagousFunction(a,b,c)
#macro connectTheDots(func, foo1, foo2)
 thisAndThis = parse(func);
connectTheDots ("lissagousFunction(3,0,1)", 5, 1)
Does it make sense?
Peter Popov
ICQ: 15002700
Subject: Re: REQ: 'parse' function
Date: 12 Jul 1999 14:56:25
Message: <378A39DF.FC6F1F4A@pacbell.net>
Peter Popov wrote:
> Greetings all.
> #end
> #end
> Does it make sense?
> Peter Popov
> ICQ: 15002700
  Me being the programming and math illeterate bofo that I am I really
don't understand what you are trying to say but I think I understand
what you are trying to accomplish none the less. Instead of the approach
you are suggesting could you not instead store the data produced by the
first macro in an array and use that to pass to the function in the
connectTheDots macro ?
P.S. There is a nice connect the dots macro available at Twyst's MacroScope
collection if you are interested.
http://macroscope.twysted.net/
Ken Tyler
mailto://tylereng@pacbell.net
Date: 12 Jul 1999 14:59:04
Message: <378A3C10.641B6D3D@compuserve.com>
All you have to do is write the string to a file and then include the
file. A macro could be made to do this, and use the same syntax.
Date: 12 Jul 1999 15:08:18
Message: <378a3d22@news.povray.org>
Good idea.  The only caveat, of course, is you wouldn't be able to
parse strings that contain calls to the parse macro.  That might not
be too big a deal, though.
Date: 12 Jul 1999 18:01:36
Message: <378A66D7.DB4AC91B@compuserve.com>
be too big a deal, though.<
Why not? Macros are capable of recursion, and it would be possible to
set it up to use different files for each macro call, wouldn't it?
Date: 12 Jul 1999 22:34:04
Message: <378AA47B.88F7C8FD@Kopp.com>
The way the parser is currently written, this would not be trivial to
add, IMHO.  Chris' suggestion is good, though (although maybe a bit slow?).
-Nathan
Peter Popov wrote:
> Greetings all.
Date: 13 Jul 1999 00:28:12
Message: <378cbf8f.74923820@204.213.191.228>
The way I am currently doing it is the way Chris offers. The problem
is that I need a good 20000 or more calls of this kind, and it gets
slow, really.
Anyway, for the purpose I need it, I should confine to official POV
only, so that's the only way to go right now. Thank you guys.
Peter Popov
ICQ: 15002700
Date: 13 Jul 1999 09:09:59
Message: <378b3aa7@news.povray.org>
Funny you should say that.... Before I read Chris' suggestion, I went
to see how hard it would be to implement and it didn't look too
difficult to do at least the nonrecursive case.  OTOH, it wouldn't be
much faster than Chris' suggestion, so why make changes to the code?
Date: 13 Jul 1999 09:22:53
Message: <378B3D92.4087CF2E@numerik.uni-kiel.de>
> slow, really.
> Peter Popov
> ICQ: 15002700
Perhaps using a temporary file can speed things up. Working on a unix
box, this would be on a ram disk, skipping all the hard disk handling.
Axel
Date: 13 Jul 1999 20:06:49
Message: <378BD5B1.575534FD@compuserve.com>
Yes, a RAM disk(that term is also used on the Mac) would definitely
better here. (now why didn't I think of that?)
Funny how different platforms use completely different language for the
exact same thing. (I like folder better than directory, though.)
