POV-Ray : Newsgroups : povray.unofficial.patches : Isosurface & float functions Server Time
23 Jul 2025 01:59:42 EDT (-0400)
  Isosurface & float functions (Message 1 to 6 of 6)
Subject: Isosurface & float functions
Date: 15 Jul 1999 12:38:13
Message: <378E0F19.C4643CA3@inapg.inra.fr>
This is something I've noticed a while ago but didn't care about until
recently : some math functions are not recognized in the isosurface
function declaration : pow, log, atan2, int, ceil, floor.
function  y + sqrt(x) works
but
function  y + pow(x,0.5) returns an error ("float factor expected but
pow found instead")
Any clue about this behavior ? Or am I missing something obvious ? It
looks like the part of the patch that parses the function declaration
doesn't know about these particular float functions.
Many thanks
Gilles
Subject: Re: Isosurface & float functions
Date: 15 Jul 1999 13:18:09
Message: <378e17d1@news.povray.org>
In article <378E0F19.C4643CA3@inapg.inra.fr> , Gilles Tran
> but
> pow found instead")
The functions in the patch do _not_ match the POV-Ray functions, they are a
separate implementation and certain functions simply do not exist.
     Thorsten
Date: 16 Jul 1999 07:42:28
Message: <378F0C7B.7813D5B7@panama.phoenix.net>
Ever hear of x^0.5?
> but
> pow found instead")
> Many thanks
> Gilles
Anthony L. Bennett
http://welcome.to/TonyB
Graphics rendered
by the Dreamachine.
Date: 16 Jul 1999 08:38:28
Message: <378F286D.5E2F189D@inapg.inra.fr>
How's that for a discovery :
"^" is an invalid operator in straight povray ("object or directive not
found but ^ found instead)
but... it works in the function{} feature of the Superpatch !!!
So it solves the problem for pow (and also the riddle of why a common
function like this was not implemented ; I suspect that R. Suzuki actually
implemented ^ support before the official povray had the pow function).
Many thanks TonyB, you saved the day (mine at least)
Gilles
TonyB wrote:
> Ever hear of x^0.5?
> > but
> > pow found instead")
> > Many thanks
> > Gilles
> Anthony L. Bennett
> Graphics rendered
> by the Dreamachine.
Date: 16 Jul 1999 22:24:30
Message: <378FDB32.27BCBBFF@panama.phoenix.net>
Sure, no problem. Glad I could be of service. =)
Anthony L. Bennett
Date: 22 Jul 1999 14:53:34
Message: <379768E3.4CB2@aol.com>
> but
> pow found instead")
pow() is supported by the ^ operator, as TonyB pointed out, so y+x^0.5
will work for you, but sqrt() is still the better way to go for its
simplicity. The function is cleaner and faster. log() doesn't work but
ln() does, so if you want a base-10 log you can always use ln(x)/ln(10).
As for atan2(), floor(), and ceil(), I added them myself, a few weeks
ago. I also added pi and clock, so you can use them directly, without
having to #declare a variable to sub in for them first. And, I added
radians() and degrees(), and if()--which is a binary function that works
like this:
if(condition,expr1,expr2)
If condition>0, return expr1
Else return expr2
I've found if() is handy for a means of bounding density functions, as I
originally intended ceil() and floor() to be.
It's actually not hard to add functions to the isosurface
implementation, so I did so. A little before you wrote this post, I
actually added function-normal calculation so that isoblobs would work
correctly (though I might find a way to go back to the old system
anyway, if I can do so easily). atan2() isn't calculating its normal
correctly, so that I may have to fudge it, but other than that the
function-normal parts can be made to work on isosurfaces as well. I
think this might in some cases be slower than the old normal-finding
method--and in some cases a lot slower--so it might be necessary to
include some sort of flag in the isoblob, as well as in the isosurface
and parametric surface (when I get around to that one) that allows it to
specify the means by which normals are calculated.
Lummox JR
