POV-Ray : Newsgroups : povray.unofficial.patches : SuperPatch function{pigment{imag_map{ Server Time
18 Apr 2026 16:06:01 EDT (-0400)
  SuperPatch function{pigment{imag_map{ (Message 1 to 2 of 2)
Subject: SuperPatch function{pigment{imag_map{
Date: 10 Jul 1999 13:03:42
Message: <37877C9D.13F2@geocities.com>
When trying out
     function{
             image_map{
                 tga "bad.tga"
with SuperPatch, I found that if the image_map file doesn't exist
or can't be read (etc), and POV tries to do its Error exit routine,
it was crashing instead.
The reason seems to be that in Pattern_Structure,
the image is a member of a C union ('Vals') which I think
is being initialized to a value for 'gradient',
so when POV tries to free up the Pattern_Structure in
order to quit, it sees the image pointer as not NULL
and tries to free the image and causes SIGSEGV.
a fix is very simple in parstxtr.c:
static void Parse_Pattern (TPATTERN *New, int TPat_Type)
     CASE (IMAGE_MAP_TOKEN)
       if (TPat_Type != PIGMENT_TYPE)
	 Only_In("image_map","pigment");
       if (Old_Type==BITMAP_PATTERN)
	 Destroy_Image(Old_Image);
       New->Type = BITMAP_PATTERN;
       New->Frequency = 0.0;
       /*a "fix"*/
       New->Vals.Image=NULL;
       Parse_Image_Map ((PIGMENT *)New);
       EXIT
     END_CASE
Density_File is part of the same union and may have a similar
problem. but I haven't even tried to find out.
Subject: Re: SuperPatch function{pigment{imag_map{
Date: 11 Jul 1999 10:04:42
Message: <3788A425.13F1@geocities.com>
no it isn't. it just isn't initialized, i think.
the Density_File member appears ok
