POV-Ray : Newsgroups : povray.unofficial.patches : Hi Ron Server Time
23 Mar 2026 20:29:14 EDT (-0400)
  Hi Ron (Message 1 to 8 of 8)
Subject: Hi Ron
Date: 8 Jul 1999 16:31:47
Message: <37850ab3@news.povray.org>
Apart from the obligatory nag about the superpatch update :) I have a
request/query
Do you remember the thread about noise and basic shapes so months ago?
Well is possible to add noise and to HFs? not in the sense of graphic noise
but in a way similar to that the isopatch uses.
If so, if it's easy to add, can we have it?
Mick
Subject: Re: Hi Ron
Date: 8 Jul 1999 17:31:34
Message: <378518b6@news.povray.org>
>request/query
I'm not sure what you mean.  Are you wanting to add a higher-frequency
noise to a lower-frequency heightfield (i.e. more than one noise sample
per pixel)?
There is a way you can fake it with the iso patch, though it's probably
kinda slow.  The 3.1e superpatch has a pigment function that, afaik,
should work with an interpolated imagemap to give you a nice isosurface
approximation of a heightfield.  Once you get that working, you can
then add any function you want to it, including noise.
Subject: Re: Hi Ron
Date: 8 Jul 1999 17:55:29
Message: <37851e51@news.povray.org>
>>request/query
>per pixel)?
Here's a sample showing what I mean.  For some reason the bilinear interpolation
doesn't seem quite as useful as I thought it would, but here ya go anyway.  You
should substitute your own heightfield where I have sphere.bmp.  The .001 is
used to chop off the planar surface that would otherwise be generated by the
black background in my test image.
//--------- cut here ----->8=======
camera {location <0,3,-3> look_at 0}
light_source {<-20,20,-20> rgb <.8,.8,1>}
light_source {<20,20,-20> rgb <1,.8,.8>}
#declare xx=function{
    image_map {
      sys "sphere.bmp"
      interpolate 2
  rotate 90*x
isosurface {
  function{y-xx(x,y,z)+.001+.05*noise3d(20*x,20*y,20*z)}
  bounded_by {box {0,1}}
  eval
  translate -.5
  scale 3
    pigment {color rgb 1}
    finish {ambient .3}
Subject: Re: Hi Ron
Date: 8 Jul 1999 18:18:26
Message: <378523b2@news.povray.org>
Sounds interesting  - I'm about to fall asleep over this keyboard so I'll
give it a go tomorrozzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz!
Mick
Ron Parker <par### [at] fwicom> wrote in message
news:37851e51@news.povray.org...
> >>request/query
noise
> >per pixel)?
interpolation
You
is
the
> file://--------- cut here ----->8=======
>   pigment {
>     image_map {
>       sys "sphere.bmp"
>       interpolate 2
>   rotate 90*x
> isosurface {
>   eval
>   translate -.5
>   scale 3
>   texture {
>     finish {ambient .3}
Subject: Re: Hi Ron
Date: 8 Jul 1999 21:59:59
Message: <378557aa.33548939@news.povray.org>
On Thu, 8 Jul 1999 18:45:17 +0100, "Mick Hazelgrove"
Wouldn't it give the same results to add noise to the original image
used for the heightfield? That might be a simpler method.
Later,
Glen Berry
IMP Vice Coordinator, and Communications Director
IMP Website: www.imp.org
My Website:  www.ezwv.com/~mclilith/index.html
Email:  7no### [at] ezwvcom
(remove the "7" to reply via personal email)
Subject: Re: Hi Ron
Date: 9 Jul 1999 02:45:32
Message: <37859a8c@news.povray.org>
No I'm not after that effect, I'm looking for something that will distort
the HF. Take one HF made of clay and push and pull it about a bit. It still
retains the basic shape but now there are xtra bumps and lumps ridges and
dents. Noise simply adds spikes.
I have a feeling that adding 3Dnoise as in the superpatch and isopatch
objects to the HF would allow undercuts. I would also like to see a twisting
call where the base remained the same but the HF was twisted as it got
higher.
Mick
Subject: Re: Hi Ron
Date: 9 Jul 1999 12:18:04
Message: <378620bc@news.povray.org>
Hi Ron
This is fantastic!!!!
I've just got home and rendered a quick pic - it opens new doors and a whole
new chapter on HFs.
I just did not realize you could use a pic as a function, brilliant idea.
Thanks
PS will post some pics later
Subject: Re: Hi Ron
Date: 9 Jul 1999 22:53:08
Message: <3788b54d.97329409@news.povray.org>
On Fri, 9 Jul 1999 14:31:27 +0100, "Mick Hazelgrove"
Credit where it's due, Matthew Corey Brown (xenoarch) is responsible
for the pigment isosurface type.  His brilliant idea, not mine. :)
