POV-Ray : Newsgroups : povray.unofficial.patches : SuperPatch / bad triangle Server Time
16 Jun 2026 21:32:31 EDT (-0400)
  SuperPatch / bad triangle (Message 1 to 5 of 5)
Subject: SuperPatch / bad triangle
Date: 30 Jun 1999 19:01:52
Message: <377AA19C.7026@geocities.com>
The following triangle makes SuperPatch POV-Ray
(at least my DJGPP build) crash with SIGSEGV when
rendered at 320x240.
Removing the 'reflection' from the triangle lets it render OK
so I assume this is one of those 'reflection normals, etc'
things.
(The same scene and resolution with official POV goes
fine.)
I am curious as to how it renders in other builds of
SuperPatch.
/*---------- bad triangle ----------------------------------*/
triangle{
        <75.194025, -159.990988, 51.303515>,
        <-110.075813, -155.973645, -48.712199>,
        <53.753353, 90.153147, 153.284065>
        texture{
                pigment { rgb<1,0,0> }
                finish { reflection .1}
        rotate<0,80,0>
camera{
        location <450.00, 0.00, 00>
        look_at <0.00, .00, 0.00>
light_source {
        <1100, 100, -200>
        color 1
Subject: Re: SuperPatch / bad triangle
Date: 30 Jun 1999 21:01:46
Message: <377cbd70.201893467@news.povray.org>
On Wed, 30 Jun 1999 19:00:44 -0400, edna dornblazer
>things.
>fine.)
Works fine in my Windows superpatch too.  Make sure your source has
the lighting.c that's dated June 10.  The older one has a bug when you
use reflection.  There was one other change from that version, too, in
render.c.
Date: 30 Jun 1999 22:30:43
Message: <377AD28B.2BBA@geocities.com>
> render.c.
lighting.c and render.c are both from June 10.
My trace says its crashing from Reflect() calling Trace()
which calls Determine_Apparent_Colour(),
and for some damn reason on the line call to Normal()
(Triangle_Normal()) which is just a memcpy from and to
a couple of perfectly fine addresses.
Could there be something just so offensive about a
particular spot (and view of that spot) on a triangle
that POV acts like this?
Date: 1 Jul 1999 13:17:23
Message: <377BA255.7E0@geocities.com>
I think I found it.
In lighting.c, in Reflect():
    z = (FRAND() * 2) - 1;
    t = FRAND() * M_PI * 2;
    r = sqrt(1 - z*z);
Well, FRAND*2 (at least with MSDOS/DJGPP) on occasion returns
numbers slightly bigger than 1.0, and the subsequent
r=sqrt(negative number) yields NaN vectors a little later.
Replacing the r=sqrt() line with
     r = sqrt(fabs(1 - z*z));
at least lets that stupid triangle render.
Date: 1 Jul 1999 14:44:37
Message: <377bb715@news.povray.org>
>I think I found it.
>    r = sqrt(1 - z*z);
Ah, that makes sense.  Windows has a tendency to ignore FP errors.
Hm, I'm piling up all sorts of bugfixes.  Time for a bugfix release,
methinks.  Now to find them all...
