POV-Ray : Newsgroups : povray.unofficial.patches : Problem with Superpatch trace function Server Time
30 Sep 2024 09:15:27 EDT (-0400)
  Problem with Superpatch trace function (Message 1 to 2 of 2)
Subject: Problem with Superpatch trace function
Date: 16 Jun 1999 13:53:43
Message: <3767E4A9.EC9427EF@fv.aetec.ee>
Hello!
I tried to use trace function from superpatch and trace intersection
with mesh object, but superpatch gave access violation. I D/L SuperPatch
source code and rebuilt project and as it appears, problem is with
uninitialized mesh queue.
Parse_Trace function calling results finally in calling function
intersect_bbox_tree (mesh.c):
static int intersect_bbox_tree(MESH *Mesh, RAY *Ray, RAY  *Orig_Ray, DBL
len, ISTACK *Depth_Stack)
  int i, found;
  DBL Best, Depth;
  RAYINFO rayinfo;
  BBOX_TREE *Node, *Root;
  /* Create the direction vectors for this ray. */
  Create_Rayinfo(Ray, &rayinfo);
  /* Start with an empty priority queue. */
  found = 0;
  Mesh_Queue->QSize = 0;
But Mesh_Queue is initialized after parse (in function
Initialize_Mesh_Code) and null pointer exception occurs. I put
Initialize_Mesh_Code call before calling Parse (after Init_Blob_Queue)
in FrameRender function (povray.c)  and this seemed to fix this problem.
Perhaps there is other uninitialized structures as well, which could
cause problems during this trace function, but at first sight I haven't
noticed such ones.
Subject: Re: Problem with Superpatch trace function
Date: 16 Jun 1999 15:38:56
Message: <3767fd50@news.povray.org>
>noticed such ones.
Thanks, I'll make a note of that one.  I already fixed the one
with the blob queue, as you may have noticed, but didn't notice
the mesh queue problem.
