POV-Ray : Newsgroups : povray.unofficial.patches : Ridged Multifractal Server Time
4 Nov 2024 13:01:14 EST (-0500)
  Ridged Multifractal (Message 1 to 10 of 12)
Subject: Ridged Multifractal
Date: 28 May 1999 23:29:19
Message: <374F5123.C318301C@istar.ca>
The Ridged Multifractal is found in a bunch of proggies, mostly HF
editors (Leveller, Wilbur, probably others).
However, it sees to have other uses. While on a whale watching trip
(didn't see any), I noticed that superimposed upon the larger scale
waves were tiny waves, which could be easily approximated by a ridged
multifractal normal. On the way to work, I saw cracks in the paint of a
wall, which again looked like a ridged multifractal, in pigment and in
normal. No other built in features of POV could accomplish this effect.
Any chance of seeing a patch with this as a pigment type (or any of the
other multifractal thingies)? Would be very handy....
Simon
http://home.istar.ca/~sdevet
Subject: Re: Ridged Multifractal
Date: 10 Jun 1999 13:36:29
Message: <375ff5d9.20547488@news.povray.org>
On Fri, 28 May 1999 23:29:56 -0300, Simon de Vet <sde### [at] istarca>
<snip>
>Simon
Where can I find info on these multifractal thingies?
Peter Popov
ICQ: 15002700
Date: 10 Jun 1999 14:32:04
Message: <376004a4@news.povray.org>
><snip>
>>Simon
I forgot about this.  The new superpatch (don't download it yet -
it has bugs) contains a library called i_fract, contributed by
Hans-Detlev Fink, that implements ridged multifractals for use with
isosurfaces.  The function name is "RidgedMultifractal" and the
parameters are as follows:
 * P0 : H
 * P1 : lacunarity
 * P2 : octaves
 * P3 : offset
 * P4 : gain
Ridged Multifractals were apparently created by F. Kenton Musgrave,
but his web page at GWU has gone offline permanently and I can't
find a replacement for it.
Date: 11 Jun 1999 06:41:29
Message: <3760E7D7.D7436C3D@neuro.informatik.uni-ulm.de>
> ><snip>
> >>Simon
>  * P0 : H
>  * P1 : lacunarity
>  * P2 : octaves
>  * P3 : offset
>  * P4 : gain
The source code of the Books "Texturing and modelling -- a procedural
approach" (first and second edition) by F. Kenton Musgrave et al. Could be
found at ftp adress:
archive.cs.umbc.edu
directory:
pub/textures
I know this, because I am writing my own HF proggie, and seached for those
fractal HF types.
Also included are the fractal types 'multifractal', 'heteroterrain' and
'hybridmultifractal' and 'fBM'.
I hope this will help
Yours
Axel Baune
Date: 11 Jun 1999 06:46:00
Message: <3760E62B.C0BE3A91@pacbell.net>
mus### [at] siggraphorg.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 11 Jun 1999 09:11:04
Message: <37610ae8@news.povray.org>
Well, yeah... I was just thinking he didn't want all that email so I
left his address out. :)  The address he gives in _Textures and Modeling:
A Procedural Approach_ (www.metacreations.com/people/musgrave) also seems
to redirect to his GWU page, but I would think it stands the best chance
of being updated or pointed elsewhere sometime in the future.
BTW, got that book from the library last night and started reading it.
Not what you'd call bedtime reading, but very very interesting nonetheless.
If you can find it and you want to know far more than you ever should need
to about procedural textures, get it.
Date: 13 Jun 1999 17:12:08
Message: <3762F8D3.9A78B58D@bigfoot.com>
> Hans-Detlev Fink, ......
Hi Ron,
I got everything compiled OK in your superpatch and I thank you for your
work. But I have no clue how to tackle the i_* bits. I never built a dll and
I do not know what the makefile should look like. I'm using mingw32/egcs if
that's any help to you for guidance you may supply.
In the hope someone can help,
Cheers,
Al.
P.S. I can give away my makefiles as they are at present (compiles the
superpatch, funny thing not resolved about the GUI stuff), but beware : I'm
no expert and they are ugly looking, yet they do the job and might help out
some lost soul.
ANTI SPAM / ANTI ARROSAGE COMMERCIAL :
To answer me, please take out the Z from my address.
Date: 13 Jun 1999 17:25:06
Message: <3766200b.5740058@news.povray.org>
On Sun, 13 Jun 1999 01:18:27 +0100, Alain CULOS
Since you're using Windows, the easiest thing to do is probably to
download the binary version and just use the i_*.dll files that are
included with it.  I think they'll work regardless of the compiler
you're using, unless yours uses a different structure-packing method
than mine does by default.  If that fails, I seem to recall that the
Cygnus webpage has a few bits about building DLLs using cygwin, which
I understand is quite similar to mingw32.  I understand that it's not
for the faint of heart.  Try
http://sourceware.cygnus.com/cygwin/cygwin-ug-net/dll.html
Date: 13 Jun 1999 19:08:53
Message: <37643920.33696339@news.povray.org>
>Hi Ron,
>Cheers,
>Al.
>some lost soul.
I use mingw32 too.  I haven't had the time/nerve to tackle the
Superpatch yet.  I do, however have a link that may help you with the
.dll compilation.  Colin Peters' webpage has a gcc tutorial that
explains .dlls and how to compile them with mingw32.  Mouse down the
page until you find the windows programming tutorial.  It is at:
http://www.geocities.com/Tokyo/Towers/6162/gcc.html.
Jerry Anning
clem "at" dhol "dot" com
Date: 20 Jun 1999 15:02:03
Message: <376C375A.1DF924D2@bigfoot.com>
<snip>
Thanks to both replies, I'll do my best at recompiling (some weeks down the road
given my current speed there).
I think C dlls with cygwin are OK, whereas C++ might cause problems due to name
mangling being different. But in any case it would be a good exercise should I
wish to generate my own functions for the iso surface patch.
I'll let you know how I get on (be patient though).
Cheers,
Al.
