POV-Ray : Newsgroups : povray.unofficial.patches : Photons and Laser Beams Server Time
20 Nov 2025 07:23:47 EST (-0500)
  Photons and Laser Beams (Message 1 to 10 of 12)
Subject: Photons and Laser Beams
Date: 9 Jun 1999 01:42:52
Message: <375DFB54.C30B434C@pacbell.net>
Before I try and fail I will instead ask. ( a novel concept isn't it :)
 Many laser light shows rely on reflecting laser beams from mirror to mirror
and tracing their path with the help of smoke to make the laser beams path
visible to the spectator. Since they use precision first surface mirrors
there is virtualy no loss of intensity of the light as it is transferred
from each mirrored surface.
 Is the above scenario possible with the reflection capabilities of the
Photon Patch or should I expect some fall off of intensity ?
 I need this information as I would like to model, for a customer, the inner
workings of a surface ablation device that uses a laser in cooperation with
a galvenomteter driven mirror system to fucntion.
Ken Tyler
mailto://tylereng@pacbell.net
Subject: Re: Photons and Laser Beams
Date: 9 Jun 1999 08:39:02
Message: <375e6066@news.povray.org>
You have to remember that the photon patch doesn't currently work with
media, so laser beams won't be visible (I have absolutely no knowlege about
the device you're after, but wouldn't it require visible laser beams in the
ablation zone?)
As for light intensity - Nathan knows better, but I'd imagine photon mapping
(which is basically backward raytracing) should produce no intensity falloff
when reflecting off a perfect mirror - just like in standard raytracing.
Margus
Ken wrote in message <375DFB54.C30B434C@pacbell.net>...
mirror
inner
>Ken Tyler
Date: 9 Jun 1999 08:50:00
Message: <375E5F29.BC0C8694@pacbell.net>
> ablation zone?)
> Margus
  Well that pretty well blows that idea all to heck. I forgot about the
lack of media intereaction. Now for my next trick...
Thanks Margus.
Ken Tyler
Date: 9 Jun 1999 08:51:48
Message: <375E5F95.FBA2A85B@pacbell.net>
> > ablation zone?)
> > Margus
> Thanks Margus.
> Ken Tyler
It will probably be easier to model using colored cylinders anyway.
Ken Tyler
Date: 9 Jun 1999 09:07:24
Message: <375e670c@news.povray.org>
Indeed. You'd probably have to use the SuperPatch's trace function, tho.
Here's a macro (by Ron Parker) that might help. I don't remember if R has to
point from the surface or toward the surface, you'll have to test it.
//Returns the mirror vector of R at surface normal N
#macro v_mirror(R,N)
  #local nN=vnormalize(N);
  #local par=vdot( R, nN );
  #local perp=R-par*nN;
  vnormalize(par*nN-perp)
Ken wrote in message <375E5F95.FBA2A85B@pacbell.net>...
>Ken Tyler
Date: 9 Jun 1999 10:47:25
Message: <375E7A99.E1B526B8@pacbell.net>
> #end
  Thanks for the tip. I doubt I will use the "Super Patch" as the new version
is still unavailable and my need for completing this in a timely manner is
great. My much older (12/98), outdated, and inefficient version of the "Super
Patch" is corrupt so no longer works plus it is not available anywhere on the
net for download. I asked yesterday when I could have a copy of the new version
of the "Super Patch" and was told to "bugger off" (so to speak :).
Ken Tyler
Date: 9 Jun 1999 13:18:03
Message: <375ea1cb@news.povray.org>
You were not.  I was joking, as I thought you were.  Furrfu.  I really
don't know when it will be online, it depends heavily on what else is
going on in my life.  Nevertheless, every time I mention it I get asked
when it's going to be back online, despite the fact that I've said more
than once that I really don't know.
If you're intersecting a ray with a planar mirror, trace isn't really
necessary because the operation is so simple.  Here's a macro to find
it, borrowed somewhat from the POV source.
#macro IntersectPlane( _PlaneNormal, PlaneOffset, RayInitial, _RayDirection )
  #local PlaneNormal=vnormalize(_PlaneNormal+<0,0,0>);
  #local RayDirection=vnormalize(_RayDirection+<0,0,0>);
  #local NormalDotDirection = vdot(RayDirection, PlaneNormal);
  #if ( abs(NormalDotDirection) < 0.00001 )
    #error "Ray parallel to mirror"
  #local NormalDotOrigin = vdot( RayInitial, PlaneNormal );
  #local Depth=(PlaneOffset - NormalDotOrigin) / NormalDotDirection;
  RayInitial+Depth*RayDirection
Of course, this assumes you haven't done anything with the mirror, like
rotating or scaling it.  If you've done that, you'll have to fix the
normal and offset appropriately.
Translate is
  #declare Offset=Offset+(Normal*Translation);
Rotate is trickier - you have to multiply the normal vector by the
transpose of the rotation matrix.  If you rotate before you translate,
though (and you probably will) you can no doubt find an easier way to
find the new normal.  Hope this all helps.
Date: 9 Jun 1999 13:25:56
Message: <375ea3a4@news.povray.org>
Wicked thought - just find three points on your plane (this is easy
enough, especially if you start with an axis-aligned plane.) and
transform each of them as you transform the plane, then recalculate
the normal and offset from them.
  #local Normal = vnormalize(vcross( c-a, b-a ) );
  #local Offset = vdot( a, Normal );
Date: 9 Jun 1999 18:22:10
Message: <375EE871.A9F87984@Kopp.com>
I agree.  Even when media interaction is impelmented, you will probably
still get better results in much less time using MUCH less memory if you
fake it.
-Nathan
Date: 9 Jun 1999 20:04:49
Message: <375EFE59.DABB4B51@pacbell.net>
I was taking yet another friendly swipe when I mentined the above.
>   #end
> #end
> Translate is
  I think I have a simple yet elegant solution in the works. Since
I have abandoned the photon technique in favor of simply connecting
cylinders from each mirror surface to the next John Van Sickles
connect the dots macro handles it well and I know how to use it
from previous experience.
  Thank you for taking the time to offer assistance.
Ken Tyler
