POV-Ray : Newsgroups : povray.unofficial.patches : Q: Splines in SuperPatch Server Time
18 May 2026 06:42:29 EDT (-0400)
  Q: Splines in SuperPatch (Message 1 to 3 of 3)
Subject: Q: Splines in SuperPatch
Date: 12 May 1999 07:53:18
Message: <37395d9e.0@news.povray.org>
Some questions on the splines in the SuperPatch. I'm trying to create random
splines, that fit in the box{<-1,0,-0.5>,<1,7,0.5>}. These splines, wil later be
used to translate seperate objects within a stack.
The method (scene below) in use seems to work, but there is one problem:
abs(POS(I/Steps).x)>1 works fine, but abs(POS(I/Steps).z)>1 gives the error:
"Bad operands for period operator". What does it mean? How to get around this?
The floats, in front of the points of the spline, are not absolut clear to me.
What is their influence? I normaly keep them evenly spread along the spline. (Is
there more documentation and what is the original location of this part of the
patch? PatchStation seems to be out of running lately)
Generating random splines and then validating wether they fit in the box works,
but is there another way? I mean is it possible to generate the controllpoints
in sutch a way, that the resulting spline is always valid? I imagine something
like a pyramid or coneshape area, generate the controllpoint within that area
and the spline is valid.
ingo
Met dank aan de muze met het glazen oog.
#version 3.1;
global_settings {assumed_gamma 1.0}
light_source {
  <500, 500,-500>
  rgb 1}
  location  < 0.0, 3.5,-8.0>
  look_at   < 0.0, 3.5, 0.0>}
background{rgb 1}
plane {-z,0
  texture { pigment {
  checker colour rgbf 1 colour rgbf 0.5}}}
#macro Rmm(Min,Max,Stream)
   Max+((Min-Max)*rand(Stream))
#end // macro
#declare Sd= seed(7);
#declare C=0;
#while (C= 0)
   #declare C=1;
   #declare POS= spline{
      cubic_spline
      -1, <Rmm(-10, 10, Sd), Rmm(-20, 0, Sd), Rmm(-10, 10, Sd)>
       0, <Rmm(-0.5, 0.5, Sd), 0, Rmm(-0.25, 0.25, Sd)>
       1, <Rmm(-0.5, 0.5, Sd), 7, Rmm(-0.25, 0.25, Sd)>
       2, <Rmm(-10, 10, Sd), Rmm(7, 27, Sd), Rmm(-10, 10, Sd)>
   #local I=0;
   #local Steps=25;
   #while (I<Steps+1)
      #if(abs(POS(I/Steps).x)>1 | abs(POS(I/Steps).z)>0.5)
         #local I=26;
         #declare C=0;
      #end // if
      #local I=I+1;
   #end // while
#end // while
#declare I=0;
#declare Steps=100;
#while (I<Steps+1)
   sphere {POS(I/Steps),0.1 pigment {rgb <1,0,0>}}
   #declare I=I+1;
#end // while
Subject: Re: Q: Splines in SuperPatch
Date: 12 May 1999 10:33:14
Message: <3739831a.0@news.povray.org>
This might be a bug.  I'll have to check it at home where the superpatch source
code is and see what's going on. In the meantime, it might work if you do
#declare foo=POS(I/Steps) and then use abs(foo.z).
http://pandora.inf.uni-jena.de/pframe.phtml/e/noo/povsp/povsp.inc is Wolfgang
Ortmann's page for the spline patch.  It includes the same documentation that
has been included with the superpatch (though I rewrote it slightly) and there
is a small tutorial as well.  The code, however, is for POV version 3.01.
Date: 12 May 1999 15:02:39
Message: <3739c23f.0@news.povray.org>
After adding the <0,0,0> vector this works fine.
Going to have a look now,
Thanks Ron,
ingo
